SNTC upload issue
ajwatson74
Unable to upload to SNTC portal from CSPC. I attached a screenshot of the errors. Can someone please assist with this issue?
Supriya Patel
Hi User,
Which version are you running? This can be checked running 'show version -d'. Is this new installment? Did upload ever work via given collector?
The CSPC will try to use the below address for issuing an upload to the backend.  Can you please see if your firewall will allow traffic on this address?
IP: 72.163.7.113
Hostname: concsoweb-prd.cisco.com
Port: 443
Supriya
The version is 2.7.
This is a new deployment.
The firewall allows
IP: 72.163.7.113
Port: 443
Hi user,
Please update me on below log for further look.
Using admin CLI login:
show version -d
From root, run below command:
cat /etc/hosts
cat /etc/sysconfig/network
wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
 Please grab below from root as well:
/opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
/opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
Supriya
