CSPC Discover ISE
gordanroberts
I am trying to discover my ISE 3595 appliances so the licensing information will show up in the SNTC portal. I am using SNMPv3. I am trying to get the engineID for the CSPC to create an allow rule for the CSPC to discover the ISE appliances.
If there is a better way to accomplish this please let me know.
Thank you
Supriya Patel
Hi Gordan,
When you login to SNTC portal, you will find latest 'PID checker' link under useful link tab. Please use to check if specific device is supported or not. Or provide me exact SN or PID so I can confirm. As well, EngineID is not mandatory field for SNMPv3 profile.
Ref guide for collector: https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-User-Guide.pdf
Supriya
