08-10-2010 08:29 AM
I am preparing to perform a code upgrade on two of our MDS 9513's. Each is currently at code level 3.3(5) and we are upgrading to code level 4.1(1c). I have licenses already installed on the switches. Does upgrading to the 4.1(x) level invalidate my current licenses? Do I need to get a license key specifically for 4.1(x)?
dkhs2310# show license usage
Feature Ins Lic Status Expiry Date Comments
Count
FM_SERVER_PKG No - Unused -
MAINFRAME_PKG No - Unused -
ENTERPRISE_PKG Yes - In use never -
DMM_FOR_SSM_PKG No 0 Unused -
SAN_EXTN_OVER_IP No 0 Unused -
PORT_ACTIVATION_PKG No 0 Unused -
SME_FOR_IPS_184_PKG No 0 Unused -
STORAGE_SERVICES_184 No 0 Unused -
SAN_EXTN_OVER_IP_18_4 No 0 Unused -
SAN_EXTN_OVER_IP_IPS2 No 0 Unused -
SAN_EXTN_OVER_IP_IPS4 No 0 Unused -
STORAGE_SERVICES_SSN16 No 0 Unused -
10G_PORT_ACTIVATION_PKG No 0 Unused -
STORAGE_SERVICES_ENABLER_PKG No 0 Unused -
Jeffrey
Solved! Go to Solution.
08-20-2010 12:49 AM
Licenses are SAN-OS/NX-OS level unaware.
As new modules/features come out that may require a license to use them, the feature will show up in newer versions of SAN-OS/NX-OS. Your license is, however, for that switch and that switch only. You can't freely move licenses around between switches.
BTW, in my opinion, I would stay away from the the 4.1.x level of NX-OS and look at going to at least a 4.2.x level of NX-OS. We've hit bugs on 4.1.1b and 4.1.3a on all of our 9513's and 9222i's. The bugs we hit in 4.1.1b caused a supervisor in one of our 9513's to go offline for 20 minutes (scared the h*ll out of me) and another bug caused our 18/4 modules running SANtap to reload at random.
Hope this helps.
Gary
08-20-2010 12:49 AM
Hope this helps.
Gary
08-23-2010 05:35 AM
We successfully performed the upgrade without any licensing issues.
All licenses were still properly installed and functional at the new
OS level.
Jeffrey
