7401 PA-FC-1G Compatibility
aretsu
A customer has two sites and needs replication between these two sites. They bought two Cisco Routers 7401ASR with PA-FC-1G for connectivity between the sites (using FCIP) - This PA has one 1G PC port!
Now, on one site they have a MDS 9120 SAN Switch, that has 1/2G FC ports (speed autosense), which I think is now problem when connecting with the 7401. That is what I read on CCO.
BUT, on the other site they have an IBM 3534F08 SAN Switch, that for what I read only has 2G FC ports (their site do not mention anything regarding 1/2G autosense), so here is my question:
Is it possible to connect the 7401 PA 1G FC port WITH the IBM SAN Switch with 2G FC ports?
Thanks for your help!
pradeepde
Level 5
Level 5
It is possible to connect the 7401 PA 1G Port to the IBM SAN switch with the 2G FC ports. I have read that these are compatible and hence should not cause a problem. I havent tried this out but i guess this setup should work.
