Hello.
In hyperflex, I have a question about attaching UCS Server..
The test environment is below.
- 3EA*AFHX240c
- HXFI 6332
The rack mounting and cabling already done.
According to Hyperflex configuration, Configuring HX servers require a vCenter, DNS, NTP server.
However, there is no way to connect HXFI to Uplink because the hardware is in a customer site.
Uplink cables has not been installed yet.
So I want to attach C220 M4 to the HXFI and then install ESXi... I think that it is possible that vCenter server can be installed in the ESXi as a Guest VM.
Is it possible to connect the server to HXFI? not compute-node..
