CFS Pending Configuration
havardmangset64
When I try to close Device Manager (MDS9509) I get the message: You may have CFS pending configuration. Do you want to continue. I get this message on all 4 switches in the fabric.
Anyone who know how to fix this problem?
user_4444
From the CLI on each switch run "sh cfs app" to see which applications are using CFS. Then go through each App using "sh cfs app name ivr" use the application where I have put ivr. To check the status of each App. Then run "sh cfs merge status name ivr" for each app. That should show if a merge has failed. Also try "sh cfs lock" to see what application has a possible lock on CFS.
user_4444
I found out which application that had a lock and cleared the lock fra Device manager
