Unable to open 2 9509 switches at the same time in Cisco Device Manager
gautamzone
Dear Friends,
There are a pair of MDS 9509 switches whose management addresses are 172.16.2.197 and 172.16.2.198.
When we try to manage these Devices through Cisco device manager, the first device opens up without any problem, but when the second 9509 is opened in Cisco Device Manager, it fails giving the following error message:
"Open udp transport failed: Address already in use: Cannot bind"
To get around this issue, if we close the first interface to the 9509 switch, then we are able to open up the second 9509 in Device Manager.
We have this problem only in Cisco device manager. If we open one switch in Cisco device manager and the other switch in Cisco Fabric Manager, it works.
Also, we can telnet to both the devices successfully at a time.
The device manager in use is 4.1.
Please find enclosed the sh version outputs for your kind reference.
Can you please help me understand the cause of this issue?
Thanks a lot
Gautam
gautamzone
Sorry, missed the attachment.
user_4444
Do you have ACL in place? Can you open a new session in Device Manager from Device, Open Last?
Michael Brown
Is it always the same MDS that fails to open, or can you open either one first, and then the second one poses the problem (no matter which one is second)?
Can you try from a second work station and see if you can open DM to both switched at the same time? I suspect the address it is complaining about is the local workstation IP, not the MDS IP.
If you open the FM map, then you click on the MDS ICONs, can you open DM to both MDS?
- Mike
