Cisco MDS 9200 Series Reset
CSCO11177789
Hi;
We use 9216 for replication on two site. Two days a go, it started to reboot itself. After reboot it works 20-40 minutes then restart again and these occures several times. We couldnt find out why ?
I attached tech-support output. Could you say something regarding to problem ?
meanwhile, i'm new at san switches.
Best regards
dakester
`show system reset-reason`
----- reset reason for Supervisor-module 1 (from Supervisor in slot 1) ---
1) No time
    Reason: Unknown
    Service:
    Version: 4.1(3a)
2) No time
    Reason: Unknown
    Service:
    Version:
3) No time
    Reason: Unknown
    Service:
    Version: 4.1(3a)
4) No time
    Reason: Unknown
    Service:
    Version: 4.1(3a) `show system reset-reason`
I don't know of any known issues or bugs.
Either the input AC source is intermittenly failing or the Chassis with Supervisor needs to be RMA'ed.
David.
I see, but we have no smartnet account for switch. Also in system room there is no any device problem except this. Could it be still ac source problem ?
What do you suggest ?
Best regards
If the switch has valid contract for the device , It should be able to get RMA    there is any underlying hardware issue.
