Cisco MDS - DS-X9704 10G module Interface not coming up
abhiasabhi
Cisco MDS 9222i - DS-X9704 10G FC interface is not coming up. Please let me know if we unshut the interface with SFP whether the RED LED will be glowing or not in Tx port. When I unshut a 4 G FC interface with SFP in it, the RED Led started glowing in Tx port of that interface, but same thing is not happening with 10 G FC interface.
Abhilash
maminhas
Abhilaash,
Can you verify first the SFP type is correct for the module.
http://www.cisco.com/en/US/partner/prod/collateral/ps4159/ps6409/ps4358/product_data_sheet09186a00801bc698.html
on table 1 check the correct SFP for DS-X9704 module.    make sure both sides have same type of SFP.
then check the command
show interface fcx/y trans details  (for the port in question)
check Rx Power    Tx Power    values ,  to verify if the signal is received and transmitted properly to rule out the layer one issues.
If there is patch panel in between   switchport to device.. then it should be checked also.
Here the SFP details,  my doubt is that if we unshut an interface whether we will get an RED LED in one of the port of that interface....
switch# show interface fc2/1 transceiver details
fc2/1 sfp is present
    Name is CISCO-EXCELIGHT
    Manufacturer's part number is SDX4102FL-C1-M
    Revision is A
    Serial number is ECL152803N5
    FC Transceiver Type is X2 Medium
    FC Connector Type is SC
    Bit Encoding is NRZ
    Protocol Type is 10GFC
    Standards Compliance Codes :
    10GbE Code Byte 0 : 10GBASE-LR
    Fiber type Byte 0 : SM, Generic
    Fiber type Byte 1 : Unspecified
    Transmission Range is 1000 (in 10m increments)
    Cisco extended id is Unknown (0x0)
    No tx fault, rx loss, no sync exists, diagnostic monitoring type is 0xc7
    SFP Diagnostics Information:
                                     Alarms                  Warnings
                                High        Low         High          Low
  Temperature  41.05 C         74.00 C     -4.00 C     70.00 C        0.00 C
  Voltage       0.00 V          0.00 V      0.00 V      0.00 V        0.00 V
  Current      45.35 mA       120.00 mA    18.00 mA   131.07 mA       0.00 mA
  Tx Power     -2.41 dBm        4.50 dBm  -12.20 dBm    0.50 dBm     -8.20 dBm
  Rx Power    -31.55 dBm --     4.50 dBm  -18.42 dBm    0.50 dBm    -14.40 dBm
  Transmit Fault Count = 2
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
Looks to me SDX4102FL-C1-M is a valid 10G SFP
Here are some thougts might help narrow down the problem
1) was that working before; anything changed recently
2) how many 10 G link you have, does that problem happen to 1 link or others also
3) swap cable/sfp/port
4) is the module (DS-X9704) module up
5) any error message from the switches at both end of the connection
6) are these 2 switches directly connected?
