05-22-2012 05:59 AM
05-22-2012 06:47 AM
write erase
write erase boot
reload
(If prompted to save run to start, say no)
David
05-22-2012 07:32 AM
Hi, Thanks for response...
One more thing.... I dont want the erase the management IP address , rest everything should revert to factory default, because i am doing it remotely i need to login... is there any way to accomplish this.
Abhilash
05-22-2012 07:59 AM
If I do "write erase" whether this will erase the username / password also...
05-30-2012 12:34 AM
it will erase your password.
if you don't want to erase every thing, what you can do is, open you configuration with notepad and put "no" in front of the configuration line. and then paste it to the switch under configuration mode
