Community column Empty...
techcrazzy
Community Member
Issue on Cisco Device Manager:
Community column list is showing blank but able to see the Role column.
Able to see the Community name from CLI.
Able to add/Delete Community from CLI.
If I try Add/Delete Community from GUI, getting the error "permission denied or feature disabled"
Screenshot attached.
regards,
KK
emcprateek_2
Community Member
Try creating a test user with admin previliges on the Switch and use that user to make the community changes. If that works then use the test user to reset admin password.
This may be cuased because CLI and SNMP credentials may be out of Sync.
