Configuring 9222i for Port-Channels to 6500
Jason White
Level 4
Level 4
I need to configure an MDS 9222i to do EhterChannel for redundant links to a Cisco 6500. I have tried to configure channel-group on the GE interface and I get an error (see below)
b0maumigrjax(config-if)# channel-group 1
command failed: Member list of different interface types not supported [created]
9222i Config
interface port-channel 1
  channel mode active
  switchport rate-mode dedicated
interface GigabitEthernet1/1
  ip address 1.1.1.10 255.255.255.0
  switchport description Core.Link.Connection.22
  no shutdown
interface GigabitEthernet1/2
  ip address 1.1.1.1.11 255.255.255.0
  switchport description Core.Link.Connection.23
  no shutdown
6500 Config
Interface Port-Channel 1
sw acc vlan 10
channel-group 1 mode active
no shut
no shut
5 Replies 5
dakester
Hi Jason,
Ethernet port channels are not supported on the 9222i.
You can place the fcip interfaces in a port-channel.
David
David,
I tried that as well. I still was not able to get the interface's to come up in sh ether summ on the switch.
fcip profile 1
  ip address 10.136.120.10
  tcp max-bandwidth-mbps 50 min-available-bandwidth-mbps 20  round-trip-time-ms 5
fcip profile 2
  ip address 10.136.120.11
interface fcip1
  use-profile 1
  peer-info ipaddr 10.136.120.13
  channel-group 1 force
  no shutdown
interface fcip2
  use-profile 2
  peer-info ipaddr 10.136.120.14
  no shutdown
Hi Jason,
This is now a fibre channel port-channel.
You can verify with these comands,
show port-channel summary
show port-channel database
show interface port-channel 1
show topology
David
David,
I must still be doing someting wrong on the switch side. The ports are sill coming up suspened. do you have an idea of what the switch code should look like?
Jason
Hi Jason,
I'm guessing the interfaces are still in the isolated vsan 4094.
config
vsan database
vsan x interface port-channel 1
vsan x interface fcip1
vsan x interface fcip2
If you are still having an issue, you may want to click on the open Service Request Link.
David
