I am getting this error message when I try to connect to the fabic. I get the same message when I launch the SAN client or when I try to add the device in web console. I am not sure what is causing this problem. Please help.
I had the same problem. the solution was to downgrade PostgreSQL. I tried using 9.x and DCNM wasn't having any of it. Downgraded to 8.3, problem was immediately solved.
Learn, share, save
