Does Cisco Fabric/Device Manager 5.0(4d) run under VM?
jenriqu
I'd like to upgrade the OS on our W2k3 to W2K8 64-bit via virtual machine. First, is it possible to run Cisco Fabric and Device Manager under VM 2K8 64-bit? Has there been any issues reported running these tools, on VM?
Not a direct answer, but I've run them under VirtualBox for testing purposes and all has been fine.
I assume the VM farm in question doesn't get it's storage via the SAN you propose to manage with this fabric manager instance?
Steven
Hi Steven
Thank you for the quick response. A great question to ask my Storage Admins and VM Admins. I will get back to you.
Hello Jayson,
Yes, Cisco Fabric Manager and Nevice Managercan run on W2k3 to W2K8 64-bit VM
http://www.cisco.com/en/US/partner/docs/switches/datacenter/mds9000/sw/5_0/release/notes/fm/fm_rel_notes_504d.html
VMs:
VMs that run any qualified or supported operating system version can run Cisco Fabric Manager.
