04-10-2017 08:52 PM
Hi All,
I want to find a Cisco switch which could support below devices simultaneously
- iSCSI Storage
- FC Storage
- LAN networking
It seems that Nexus 5k can achieve my goal, right? besides, could you tell me the biggest difference between Nexus 5672UP and 5672up-16GB?
thanks for your comments.
Solved! Go to Solution.
04-10-2017 11:54 PM
both supports FC with Unified ports . the key difference regular on supports up to 8Gbps FC. while oUP-16G supports 16Gbps speed as well
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/datasheet-c78-730760.html?cachemode=refresh
04-10-2017 10:22 PM
Check license an feature to see what is available and enabled
show license
show feature
FCOE is the way to reach your FC goals.
04-10-2017 10:55 PM
Thanks.
means I need to buy license?
N5K physically supports FC and iSCSI, Only need license, right?
04-10-2017 11:54 PM
