10-11-2012 03:03 PM
I have two sites connected by 96 strands of fibre. At each site I have an IBMv7000 relicating to the other one. For iSCSI traffic I have two Cisco 3750 switches, each are in 2 switch stack.
SAN A Fibre Link SAN B
Cisco Stack A =========================Cisco Stack B
iSCSI Clients iSCSI Clients
My question: Is it ok to connect the the two stacks with etherchannel using the fibre links? Will is provide the necessary redundancy, if one of the interfaces goes down?
10-12-2012 03:51 AM
yes you can create a cross stack etherchannel. You have to use LACP though PAgP doesn't support it.
01-17-2013 12:58 AM
What model numbers of 3750 are you using?
What is the distance between the stacks as this will dictate your fiber run modules.
