FCOE design
jdclingan
I currently have a nexus 5010 with 10gb hosts and fiber attached storage at location A. At location B, I have an additional nexus 5010 with 10gb host with a CNA that will be using fcoe to connect to storage.
I'd like for the host at location B to connect FCOE to the fiber attached storage at location A. What configuration steps do I need to take to get location A's storage visible to FCOE. As I see it, I need to enable FCOE, allow the FCOE vlan, and tie that vlan to the vsan. At this point should location A be able to see B's storage? Thanks
e.nieuwstad
Over here they describe a multihop FCOE solution.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/VMDC/tech_eval/mFCoEwp.html
However they still use dedicated links for FCOE traffic from the N5K towards the N7K's and a dedicated vPC for the normal LAN traffic. They even use a dedicated VDC for storage and normal traffic.
Therefore I am not sure if it is supported to mix the ethernettraffic with the FCOE traffic one one link.
