Ficon port addressing for MDS 9506
hdsrafraco
I'm configuring a MDS 9506 as a mirror of a MDS 9513 because my customer is preparing a data center migration.
I've found that 9506 has a ficon address limit of 153, but I need to address ports up to address 230.
Do you know if there is possible to increase this limit?
Rafael
Vu Phan
Hello Rafael,
On Cisco MDS 9506, there are Implement and unimplement ports
Implemented ports: ports assigned by default up to 153
Unimplemented ports: 154 through 253, this can be assigned on demand
use the command:
switch# show ficon port-numbers assign slot xx
switch# conf t
switch(config)# ficon slot XX assign port-numbers 153 - 230  < ---  depending available ports
Hope this help
Thanks Vu Fhan for your answer.
I tried to do this that you say but the problem is that this port-numers are out of the assignable range.
switch(config)# ficon slot 4 assign port-numbers ?
  <0-153>           Enter port numbers
  <0x0-0xffffffff>  Enter port numbers
switch(config)# ficon slot 4 assign port-number 145,120,77,121,126,83,151,144,154
Invalid value/range at '^' marker.
Rafael
