Help ordering a Nexus 5548P without FC or FCoE
aguia05
I need two Nexus 5548P for iSCSI and ethernet traffic, FC and FCoE is not a requirement. The switch must have two redundant power supply and FANs.
Ordering the chasis with this part number is sufficient:
N5K-C5548P-FA
I need to order the base software, FANS, Power Supply, etc .. separately?
Prashanth Krishnappa
You might want to go with the Unified port version(UP) instead of the P since it gives you an option for FC if needed at a later date and there is no price difference.
N5K-C5548UP-FA           Nexus 5548 UP Chassis, 32 10GbE Ports, 2 PS, 2 Fans
N5KUK9-521N1.1 Nexus 5000 Base OS Software Rel 5.2(1)N1(1)
You will also need to select the required power cables.
You can always use the configurator tool
https://apps.cisco.com/qtc/config/jsp/configureHome.jsp
Thanks ...
