Invalid command (unexpected token) at '^' marker ?
waszkjaso
Anyone ever get this error before?
conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)# fcalias name LM_212 vsan 101
Switch(config-fcalias)# member interface fc1/26 swwn 20:00:00:0c:cc:g8:21:c1
Invalid command (unexpected token) at '^' marker.
dakester
I haven't see this before, but the swwn is invalid because g is is not hex.
Try using the wwn in the output of 'show interface fc1/26'.
fc1/26 is down (SFP not present)
    Hardware is Fibre Channel
    Port WWN is 20:c1:00:0d:ec:a2:1e:00 <-------
What version of NX-OS gave you the unexpected token message?
This is the response at NX-OS 5.2(2)....
9513-2(config-fcalias)# member interface fc1/1 swwn 20:00:00:0c:cc:g8:21:c1
% Invalid command at '^' marker.
(Where ^ is under the g)
David.
I'm sorry, I suggested using the fwwn of fc1/26.
You probably want the swwn of the switch.
9513-2(config-fcalias)# show wwn switch
David
