Latency Bandwidth Computation for NCS2006
Emyrsonn Rodil
Can someone provide a guidelines in calculating latency in NCS2006...
What are the things to consider on this?
Sample setup:
Point - to - Point setup
equipment with 10x10LC and 10GE client port.
thanks
kvapil_tomas
Do you use CTP? Latenci of all channels are calculated here. Otherwise it depends on the number of cards on the path and the length of optical cable.
