07-09-2012 01:32 PM
Howdy,
Recently had a 9120 stop working on me. The Status LED is orange, and stays orange. I read from the Hardware Troubleshooting:
"The Status LED flashes orange once and stays orange during diagnostic boot tests. It turns green when the switch is operational (online). If the system software cannot start up, this LED stays orange."
I do get this message from the console:
"INIT: cannot execute "/isan/bin/sysmgr_spawn"
INIT: Id "sm" respawning too fast: disabled for 5 minutes"
I tried logging into the switch, but doesn't seem to want to take my pw for admin. I also tried reseting the pw using the password recovery steps, but Ctrl+] doesn't seem to do diddly.
Wasn't sure if anyone would be able to assist, as it seems I do not have support because my SN isn't even in the system...
07-09-2012 06:05 PM
Hi John,
When you tried the Ctrl+] password reset were you able to run through the procedure or did you not get any response back from the switch?
Also, have you tried reloading the images?
07-10-2012 06:06 AM
Brian,
When I tried the Ctrl+] nothing happened, so I couldn't even try the procedure. I tried on another computer using Putty as opposed to Hyperterminal, but didn't seem to make a difference.
Reload the image? No I have not tried that. Would I need to login for that, or just change the boot options to TFTP?
Thanks.
07-10-2012 06:39 AM
Hi John,
Once the bios loads try pressing ctrl-c
You should get loader>
from there you can type:
boot bootflash:m9100-s1ek9-kickstart-mz.3.0.2a.bin (or whatever the kickstart image name is)
config terminal
admin-password newpass123
exit
load bootflash:m9100-s1ek9-mz.3.0.2a.bin (or whatever the system image name is)
To reload the images you don't need to login to the switch (http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_3_x/troubleshooting/guide/ts_sw.html#wp746790)
07-10-2012 01:40 PM
Brian,
ctrl-c only seems to do anything if I press it before the bios, to get into the bios settings screen. Anything after does not seem to do anything. I will keep trying to see if maybe I'm getting it at the incorrect time.
Thanks.
