MDS 9124, empty zone databse ?
ernest1lojan
hello
One of my customer has 2 x MDS 9xxx switches and Qlogic SANbox5600 in one fabric. Principal switch is MDS 9124, I am going to make some changes is this environment - add new storage arrays and modyfing zoning, in preparation phase I discovered that on principal switch show running-config command do not display any zones! in same time show active zoneset display properly configuration of zoneset in that fabric. On other switches in fabric runnin-config is exactly the same with active zoneset.
I am wondering if command: zone copy active-zoneset full-zoneset vsan 1 make copy of zones from active-zoneset to local database of that switch and does it secure to procceed with that command in production hours?
thanks in advance for any suggestion
dakester
"zone copy active-zoneset full-zoneset vsan x" is non-disruptive.
You may want to enable full zoneset distribution.
From the MDS switch that activated the zoneset,
zoneset distribute vsan x
From all the MDS switches
config
zoneset distribute full vsan x
This will distriubte the full zoning db every time a zoneset is activated.
Now the full zoning database will be the same on all the MDS switches.
More about zone distriution
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/4_1/configuration/guides/cli_4_1/zone.html#wp1753327
This presumes you are not activating the zoneset from the Qlogic switch.
David
hello
Thanks for explanation.
Do You know in what circumstances I can activate zoneset from Qlogic ? which setting check/change to do it in safty way for whole fabric ?
Ernest
