03-03-2011 12:02 AM
Hi I'm completely new to CISCO, so new i still have my MDS switches in the box.
We have purchased 2 MDS 9134, with the 10Gb Link cable (Copper Emulex) and full licenses.
My quesion is, can i link say port 1 on switch1 with port 1 on switch2 to get better throughput 2 x 4gb = 8gb, something little a trunk or etherchannel in the Ethernet world?
03-04-2011 11:43 AM
Yes, you can use the concept of port-channel to bundle the ports on MDS9134
Pre-requisite
connect MDS1 fc1/1 to MDS2fc1/1
connect MDS2 fc1/2 to MDS2fc1/2
Ex:
MDS1
conf t
interface fc1/1
switchport mode E
switchport speed 4000
channel-group 1 force
interface fc1/2
switchport mode E
MDS2
conf t
interface fc1/1
switchport mode E
interface fc1/2
switchport mode E
03-05-2011 03:42 PM
what was the reason of buying these switches ? If this is going going to be used for your SAN fabric than you want to have two separate fabrics: Fabric A and Fabric B, each fabric will consist of one switch. Having two redundant fabrics eliminates single point of failure as far as SAN fabric is concerned.
