MDS 9148 and HP HBA compatibility.
Fernando Bello
Hello All,
The IT department is planning to change some HBA cards to some of our servers. The HBA cards manufacturer is HP
AP770B - HP 82B PCIe 8Gb FC Dual Port HBA
AJ763B -  HP 82E 8Gb Dual-port PCI-e FC HBA
QR559A - HP SN1000E 16Gb 2P FC HBA
AJ764A  - HP 82Q 8Gb Dual Port PCI-e FC HBA
We have an MDS 9148 switch that will be connected to one of these HBA cards. The IT department has asked me to tell them if one of the cards above is compatible with the CISCO MDS 9148 hardware. I've been looking for a pdf or document about compatibility matrix but I did not find anything. THe question here is: "Does CISCO provide a datasheet about compatibility matrix between HBA cards and MDS 9000 switches?"
Thanks in advance for your help.
Fernando
Daniel Laden
Level 4
Level 4
Disk Storage Interoperability Matrix
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/interoperability/matrix/Matrix1.html
Review table 1-2
Thank You,
Dan Laden
Cisco PDI Data Center
Need assistance with an implementation?
http://www.cisco.com/go/pdihelpdesk
Daniel Laden
Level 4
Level 4
Review table 1-2
Thank You,
Dan Laden
Thanks so much Daniel!
Fernando
