MDS 9148 NX-OS 5.0(1a) Link failure Problem
Fernando Bello
Hi all,
I'm finding the following problem on my 2 MDS9148 switches.
2012 May  7 14:15:54 SAN01 %PORT-4-IF_SFP_WARNING: Interface fc1/7, Low Rx Power Warning  BK01
2012 May  7 14:15:54 SAN01 %PORT-3-IF_SFP_7ALARM: Interface fc1/7, Low Rx Power Alarm  BK01
And finally the FC interfaces go down. We checked the fiber cable to be sure that it is not a physical issue and the fiber cables are ok.
This happens with fc1/1, 1/3, 1/4 and several more.
Does anyone have an idea why this could be happening and what the error might be?
Your help will be much appreciated.
Thanks in advance,
Kind regards
14 Replies 14
krun_shah
Are those ISL ports? What is connected to those ports?
Collect following and post it here
sh int fc1/7 counters  details
sh int fc 1/7 transceiver details
Krun_shah,
I am posting the fc1/1 and fc1/5 instead of fc1/7. All of them are experiencing the same
problem.
To those ports is connected one of the drives of a backup robot.
THe interfaces I believe they are not ISL. (You mean ISL as a trunking method, right?)
Here it is the config of each interface.
interface fc1/1
  switchport description LTO3
  port-license acquire
  no shutdown
interface fc1/5
  no shutdown
Here are the details for fc1/1 and fc1/5 that are experiencing the same problem as fc1/7.
#sh int fc1/1 counters  details  fc1/1        4417757720 frames, 5859624695228 bytes received       0 class-2 frames, 0 bytes received       0 class-2 discards       0 F_BSY frames, 0 F_RJT frames           generated against class-2 frames       0 port reject frames       4417757720 class-3 frames, 5859624695228 bytes received       0 class-f frames, 0 bytes received       0 discards, 0 errors received       0 discards, 117 errors transmitted       100604456388 frames, 207142346384892 bytes transmitted       0 class-2 frames, 0 bytes transmitted       100604456388 class-3 frames, 207142346384892 bytes transmitted       0 class-3 frames discarded       0 class-f frames, 0 bytes transmitted       0 class-f frames discarded       0 multicast packets received, 0 transmitted       0 broadcast packets received, 0 transmitted       4417756190 unicast packets received, 100611090558 transmitted       85 link failures, 82 sync losses,       77 signal losses       0 primitive sequence protocol errors       163601 invalid transmission words       0 invalid CRCs, 0 Delimiter Errors       0 address identifier errors       0 link reset protocol errors received       0 link reset protocol errors transmitted       0 Offline Sequence errors received       173 Offline Sequence errors transmitted       0 frames received that are shorter than           the minimum allowable frame length           regardless of the CRC error       0 frames received that are longer than           the maximum frame length and also have a           CRC error       0 waits due to lack of transmit credits       0 frames received with length greater           than what was agreed to in FLOGI/PLOGI       0 frames received with length less than           the minimum indicated by the frame header       0 link reset responses received       0 link reset responses transmitted       0 non-operational sequences received       88 non-operational sequences transmitted       0 fragmented frames received       0 frames received with EOF aborts       0 unknown class frames received       0 8b10b disparity errors       117 frames discarded       0 Exchange Link Parameters switch fabric           internal link service request failures       110542953 transitions of BB credit out of zero state       0 transitions of BB credit to zero state       0 Enhanced Inter Switch Link (EISL) frames           discarded       0 framing errors       0 F8 type LIP sequence errors received       0 F8 type LIP sequence errors issued       193 Non F8 type LIP sequence errors received       173 Non F8 type LIP sequence errors issued  # sh int fc 1/1 transceiver details  fc1/1 sfp is present      Name is CISCO-AVAGO          Manufacturer's part number is SFBR-5780APZ-CS2     Revision is G2.3     Serial number is AGD143284VM          FC Transmitter type is short wave laser w/o OFC (SN)     FC Transmitter supports short distance link length     Transmission medium is multimode laser with 62.5 um aperture (M6)     Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s     Nominal bit rate is 8500 Mb/s     Link length supported for 50/125mm fiber is 50 m     Link length supported for 62.5/125mm fiber is 20 m     Cisco extended id is unknown (0x0)      No tx fault, no rx loss, in sync state, diagnostic monitoring type is 0x68     SFP Diagnostics Information: ----------------------------------------------------------------------------                                      Alarms                  Warnings                                 High        Low         High          Low ----------------------------------------------------------------------------   Temperature  34.66 C         75.00 C     -5.00 C     70.00 C        0.00 C   Voltage       3.27 V          3.63 V      2.97 V      3.46 V        3.13 V   Current       7.09 mA         8.50 mA     2.00 mA     8.50 mA       2.00 mA   Tx Power     -2.91 dBm        1.70 dBm  -14.00 dBm   -1.30 dBm    -10.00 dBm   Rx Power     -6.76 dBm        3.00 dBm  -17.30 dBm    0.00 dBm    -13.30 dBm   Transmit Fault Count = 0 ----------------------------------------------------------------------------   Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning   # sh int fc1/5 counters  details  fc1/5        4486944237 frames, 5759105445416 bytes received       0 class-2 frames, 0 bytes received       0 class-2 discards       0 F_BSY frames, 0 F_RJT frames           generated against class-2 frames       0 port reject frames       4486944237 class-3 frames, 5759105445416 bytes received       0 class-f frames, 0 bytes received       0 discards, 0 errors received       0 discards, 2 errors transmitted       108664953452 frames, 223758725747704 bytes transmitted       0 class-2 frames, 0 bytes transmitted       108664953452 class-3 frames, 223758725747704 bytes transmitted       0 class-3 frames discarded       0 class-f frames, 0 bytes transmitted       0 class-f frames discarded       0 multicast packets received, 0 transmitted       0 broadcast packets received, 0 transmitted       4486942834 unicast packets received, 108671587794 transmitted       63 link failures, 62 sync losses,       6 signal losses       0 primitive sequence protocol errors       124 invalid transmission words       0 invalid CRCs, 0 Delimiter Errors       0 address identifier errors       0 link reset protocol errors received       0 link reset protocol errors transmitted       0 Offline Sequence errors received       129 Offline Sequence errors transmitted       0 frames received that are shorter than           the minimum allowable frame length           regardless of the CRC error       0 frames received that are longer than           the maximum frame length and also have a           CRC error       0 waits due to lack of transmit credits       0 frames received with length greater           than what was agreed to in FLOGI/PLOGI       0 frames received with length less than           the minimum indicated by the frame header       0 link reset responses received       0 link reset responses transmitted       0 non-operational sequences received       66 non-operational sequences transmitted       0 fragmented frames received       0 frames received with EOF aborts       0 unknown class frames received       0 8b10b disparity errors       2 frames discarded       0 Exchange Link Parameters switch fabric           internal link service request failures       294071266 transitions of BB credit out of zero state       0 transitions of BB credit to zero state       0 Enhanced Inter Switch Link (EISL) frames           discarded       0 framing errors       0 F8 type LIP sequence errors received       0 F8 type LIP sequence errors issued       134 Non F8 type LIP sequence errors received       129 Non F8 type LIP sequence errors issued  # sh int fc 1/5 transceiver details  fc1/5 sfp is present      Name is CISCO-AVAGO          Manufacturer's part number is SFBR-5780APZ-CS2     Revision is G2.3     Serial number is AGD143284VS          FC Transmitter type is short wave laser w/o OFC (SN)     FC Transmitter supports short distance link length     Transmission medium is multimode laser with 62.5 um aperture (M6)     Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s     Nominal bit rate is 8500 Mb/s     Link length supported for 50/125mm fiber is 50 m     Link length supported for 62.5/125mm fiber is 20 m     Cisco extended id is unknown (0x0)      No tx fault, no rx loss, in sync state, diagnostic monitoring type is 0x68     SFP Diagnostics Information: ----------------------------------------------------------------------------                                      Alarms                  Warnings                                 High        Low         High          Low ----------------------------------------------------------------------------   Temperature  36.53 C         75.00 C     -5.00 C     70.00 C        0.00 C   Voltage       3.26 V          3.63 V      2.97 V      3.46 V        3.13 V   Current       7.08 mA         8.50 mA     2.00 mA     8.50 mA       2.00 mA   Tx Power     -2.72 dBm        1.70 dBm  -14.00 dBm   -1.30 dBm    -10.00 dBm   Rx Power     -3.94 dBm        3.00 dBm  -17.30 dBm    0.00 dBm    -13.30 dBm   Transmit Fault Count = 0 ----------------------------------------------------------------------------   Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
Krun_shah
Seems that the other post has not a good layout.
Here it is: THe error:
2012 Sep  4 09:34:43 SAN-01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/1 is down (Link failure)  LTO3
2012 Sep  4 09:34:44 SAN-01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/1 is down (Link failure)  LTO3
2012 Sep  4 09:34:44 SAN-01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/5 is down (Link failure)  LTO3
2012 Sep  4 09:35:31 SAN-01 %PORT-2-IF_DOWN_LINK_FAILURE: %$VSAN 2%$ Interface fc1/5 is down (Link failure)  LTO3
2012 Sep  4 09:35:31 SAN-01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/1 is up in mode FL  LTO3
2012 Sep  4 09:35:33 SAN-01 %PORT-5-IF_UP: %$VSAN 2%$ Interface fc1/5 is up in mode FL  LTO3
2012 Sep  4 09:36:57 SAN-01 %PORT-4-IF_SFP_WARNING: Interface fc1/1, Low Rx Power Warning  LTO3
2012 Sep  4 09:36:57 SAN-01 %PORT-4-IF_SFP_WARNING: Interface fc1/5, Low Rx Power Warning  LTO3
2012 Sep  4 09:36:57 SAN-01 %PORT-3-IF_SFP_ALARM: Interface fc1/5, Low Rx Power Alarm  LTO3
2012 Sep  4 09:46:58 SAN-01 %PORT-4-IF_SFP_WARNING: Interface fc1/1, Low Rx Power Warning cleared  LTO3
2012 Sep  4 09:46:58 SAN-01 %PORT-3-IF_SFP_ALARM: Interface fc1/1, Low Rx Power Alarm cleared  LTO3
2012 Sep  4 09:46:58 SAN-01 %PORT-4-IF_SFP_WARNING: Interface fc1/5, Low Rx Power Warning cleared  LTO3
2012 Sep  4 09:46:58 SAN-01 %PORT-3-IF_SFP_ALARM: Interface fc1/5, Low Rx Power Alarm cleared
The fc1/1 and fc1/5 ports are experiencing the same problem as fc1/7 so I am pasting the show command output for those ports.
The fc1/1 and fc1/5 are not ISL ports I believe. You mean ISL as the trunking protocol, right?
Here it is the config for both ports.
interface fc1/1
  no shutdown
interface fc1/5
  no shutdown
WE have connected to those ports a drive that is used by a backup robot.
Here are the ouput for the show commands you asked.
fc1/1
      0 class-2 discards
          CRC error
          discarded
      0 framing errors
SAN-01# sh int fc 1/1 transceiver details
    Name is CISCO-AVAGO
    Revision is G2.3
                                     Alarms                  Warnings
                                High        Low         High          Low
SAN-01# sh int fc1/5 counters  details
fc1/5
      0 class-2 discards
          CRC error
      2 frames discarded
          discarded
      0 framing errors
SAN-01# sh int fc 1/5 transceiver details
    Name is CISCO-AVAGO
    Revision is G2.3
                                     Alarms                  Warnings
                                High        Low         High          Low
thanks in advance,
Fernando
do you have other tape drives that are connected to this switch and are working correctly ? If yes, can you move them to these ports and move the other drives to "working" ports and see if the problem follows those specific tape drives.
@dynamoxxx
Hi dynamoxxx,
From port fc1/1 to f1/16 we have connected different things, servers, drives and other devices. And all ports are experiencing the same problem.
Thanks!
Fernando
i would not think that 6 SFPs would go bad but have you tried to swap those from other know "working" ports ? Also are these direct connects or you are going through a patch panel of some sort ?
@dynamoxxx
Hi Dynamoxx,
Sorry for the late response, but I was sure that I have answered the question you asked previously.
Yes, fibers go through a patch panel. Above, I pasted the output of "show fc1/1 transceiver detail" and the output I got was the following:
    Name is CISCO-AVAGO
    Revision is G2.3
    Transmission medium is multimode laser with 62.5 um aperture (M6)*********************************************
    Nominal bit rate is 8500 Mb/s******************************************************************************************
As you can see, it says that the transmission medium is multimode laser with 62.5 um and the nominal rate is 8500 Mb/s.
Is it possible that the transceiver is able to detect what type of fiber is it connected? Is that a default value? May I change that value from the command line?
Besides, the nominal rate, what does exaclty mean and is it possible to modify it?
the GBIC model is DS-SFP-FC8G-SW
thanks in advance for your help,
Fernando
Fernando,
I'm having the same problem, did you solved your?
Thanks in advance,
Roberto
Roberto,
No, some tests still need to be done, but unfortunately, the problem still exists. If I find the solution, I will let you know ASAP.
thanks,
Fernando
Fernando,
Thank you for your prompt reply. I have one more question, have you tried to upgrade the firmware to the 5.2 version?
Roberto
Filiph Westman
This is a known software problem (no functional impact). The alarm displays a few minutes after the interface comes up, then clears about 10 minutes later. Solved in NX-OS 4.2(7e) or 5.0.7 and later (CSCtk10527)...
--filiph
Hi Filiph,
thanks for your response. I will check if the upgrade is possible and then let you know the results.
Thanks!
Fernando
Just to clarify....
you still need to investigate why ports go offline with LINK FAILURE as the cause (check logs on the LTO device and the physical connection).
The following "Low Rx Power Warning" is a cosmetic issue that happens when link goes online again.
--filiph
raghu.grandhi
Hi All,
I'm having the same problem currently using NX-OS Version 5.1(3)N1(1a) why this is updated version but same problem any one help.
2013 Jun  9 14:05:50 NXS01 %PORT-4-IF_SFP_WARNING: Interface fc2/4, Low Rx Power Warning
2013 Jun  9 14:05:50 NXS01 %PORT-3-IF_SFP_ALARM: Interface fc2/4, Low Rx Power Alarm
