Bookmark
Subscribe
785
MDS 9509 upgrade
baisangsang
I want to upgrade mds 9509 from SAN-OS 3.1.x to 3.3.5b.
I can not use 'install all'
so how can I upgrade the two supervisor (active and HA-standby) in another way?
jihicks
First, I need to understand why you can not use "install all" to be able to suggest alternatives.
Best regards,
Jim
Because the leader do not want to use 'install all', so I must find another way.
"Install all" is the only supported way by Cisco to do the firmware upgrade..
a...a....a...a.. thank you ~~
