MDS 9513 System version is installed or not?
jrodrigval
A few minutes ago checking something into our switches I realize that we have two different system versions, what is the "real one"???
CNA252040RSAN# sh hardware
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2015, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
BIOS: version 1.0.10
loader: version N/A
kickstart: version 6.2(13a)
system: version 6.2(13a)
BIOS compile time: 01/08/09
kickstart image file is: bootflash:///m9500-sf2ek9-kickstart-mz.6.2.13a.bin
kickstart compile time: 8/31/2015 23:00:00 [08/25/2015 12:33:44]
system image file is: bootflash:///m9500-sf2ek9-mz.6.2.13a.bin
system compile time: 8/31/2015 23:00:00 [08/25/2015 14:36:20]
Hardware
cisco MDS 9513 (13 Slot) Chassis ("Supervisor/Fabric-2")
Motorola, 7447A, altivec with 1032996 kB of memory.
Processor Board ID JAE11441W1H
Device name: CNA252040RSAN
bootflash: 1000440 kB
slot0: 0 kB (expansion flash)
Kernel uptime is 148 day(s), 6 hour(s), 38 minute(s), 18 second(s)
Last reset
Reason: Unknown
System version: 5.2(8g)
Service:
plugin
Core Plugin
When we take care of the service the previous guys said to us that they upgrade the switches but they didn't I'm afraid...
Checking the "show hardware" command we suppose that they "just" upload to the switch the new firmware file but they never upgrade the switch doing the all procedure, I am correct?
If the answer is yes, should we proceed to do the all upgrade procedure??? (maybe this document?: http://www.cisco.com/c/en/us/support/docs/storage-networking/mds-9000-nx-os-san-os-software/118952-technote-mds9k-00.html), I am right?
Or what we should do?
Thanks in advance for your help.
2 Accepted Solutions
reregala
According to the output, the switch is running 6.2(13a). The bottom part just shows the previous version when it went down for a reset. We can conclude that in the last reset, the switch was running 5.2(8g).
Also, the switch booted with the following images:
I dont believe there is any issues here based on the output provided.
This looks good to me as well;
the last reset reason probably came during the Firmware upgrade.
you can track if this is the case: uptime is 149+ days !
Walter.
5 Replies 5
Walter Dey
What is the output of
show module
show version
Could it be, that not both sup's have been upgraded ?
Hi, I let the output you asking (show module - show version):
Thank you very much for your help.
CNA252040RSAN# show module
Mod  Ports  Module-Type                         Model              Status
1    24     1/2/4 Gbps FC Module                DS-X9124           ok
2    24     1/2/4 Gbps FC Module                DS-X9124           ok
3    48     1/2/4 Gbps FC Module                DS-X9148           ok
4    48     1/2/4 Gbps FC Module                DS-X9148           ok
5    48     1/2/4 Gbps FC Module                DS-X9148           ok
6    48     1/2/4 Gbps FC Module                DS-X9148           ok
7    0      Supervisor/Fabric-2                 DS-X9530-SF2-K9    ha-standby
8    0      Supervisor/Fabric-2                 DS-X9530-SF2-K9    active *
9    48     1/2/4 Gbps FC Module                DS-X9148           ok
10   24     1/2/4 Gbps FC Module                DS-X9124           ok
11   24     1/2/4 Gbps FC Module                DS-X9124           ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    6.2(13a)        1.5     20:01:00:0d:ec:3c:bd:80 to 20:18:00:0d:ec:3c:bd:80
2    6.2(13a)        1.5     20:41:00:0d:ec:3c:bd:80 to 20:58:00:0d:ec:3c:bd:80
3    6.2(13a)        1.5     20:81:00:0d:ec:3c:bd:80 to 20:b0:00:0d:ec:3c:bd:80
4    6.2(13a)        1.5     20:c1:00:0d:ec:3c:bd:80 to 20:f0:00:0d:ec:3c:bd:80
5    6.2(13a)        1.5     21:01:00:0d:ec:3c:bd:80 to 21:30:00:0d:ec:3c:bd:80
6    6.2(13a)        1.5     21:41:00:0d:ec:3c:bd:80 to 21:70:00:0d:ec:3c:bd:80
7    6.2(13a)        1.4     --
8    6.2(13a)        1.4     --
9    6.2(13a)        1.5     22:01:00:0d:ec:3c:bd:80 to 22:30:00:0d:ec:3c:bd:80
10   6.2(13a)        1.6     22:41:00:0d:ec:3c:bd:80 to 22:58:00:0d:ec:3c:bd:80
11   6.2(13a)        1.7     22:81:00:0d:ec:3c:bd:80 to 22:98:00:0d:ec:3c:bd:80
Mod  MAC-Address(es)                         Serial-Num
1    00-1b-54-02-70-18 to 00-1b-54-02-70-1b  JAE1139XZ3A
2    00-1b-54-02-b7-b6 to 00-1b-54-02-b7-b9  JAE11463BUZ
3    00-1b-54-02-b3-66 to 00-1b-54-02-b3-69  JAE114632N3
4    00-1b-54-02-b3-62 to 00-1b-54-02-b3-65  JAE11463K9E
5    00-1b-54-02-b3-16 to 00-1b-54-02-b3-19  JAE11463BSF
6    00-1b-54-02-c1-be to 00-1b-54-02-c1-c1  JAE11463K99
7    00-19-56-8f-68-06 to 00-19-56-8f-68-09  JAE114634JB
8    00-19-56-8f-66-f2 to 00-19-56-8f-66-f5  JAE11441W1H
9    00-1b-54-02-b4-e6 to 00-1b-54-02-b4-e9  JAE11463K8P
10   00-13-80-a8-8d-c6 to 00-13-80-a8-8d-c9  JAE1233RQRD
11   00-19-e7-a8-58-b8 to 00-19-e7-a8-58-bb  JAE1238VDWL
Xbar Ports  Module-Type                         Model              Status
1    0      Fabric Module 1                     DS-13SLT-FAB1      ok
2    0      Fabric Module 1                     DS-13SLT-FAB1      ok
Xbar Sw              Hw      World-Wide-Name(s) (WWN)
1    NA              1.1     --
2    NA              1.1     --
Xbar MAC-Address(es)                         Serial-Num
1    NA                                      JAE1139Y8ZZ
2    NA                                      JAE1139Y8VY
* this terminal session
CNA252040RSAN# show version
Software
  loader:    version N/A
Hardware
  slot0:         511664 kB (expansion flash)
Kernel uptime is 149 day(s), 4 hour(s), 24 minute(s), 51 second(s)
Last reset
  Reason: Unknown
  Service:
plugin
  Core Plugin
Walter.
reregala
Yes, I think that too but I am not completely sure.
So, you think that the 5.2(8g) is just about that "last reset"? Interesting, It could be.
