Nexus 5548UP to UCS FCoE connection
We are planing to connect Nexus 5548UP to UCS FI through FCoE link.Also we preffer to do the zoning in Nexus.
For abov requrement my understaning is we should run UCS in NPV mode(default in end-host-mode) and Nexus in NPIV mode.
Do we need any additional lisence for this??
Walter Dey
I think there is a confusion here.
FI in NPV mode refers to classical fibre channel, Nexus in NPIV mode as well ! This would be a classical fibre channel solution
If you consider FCoE North bound, this is called multi hop FCoE; 1. hop between blade and FI, 2. hop between FI and N5k.
You configure a FI Ethernet port as a FCoE uplink port, and the same port as a Uplink port; the result will be a unified uplink port, transporting FCoE and IP.
The concept of a FCoE NPV on N5k exists as well (outside of UCS), see e.g. http://www.ciscopress.com/articles/article.asp?p=2030048&seqNum=4
Configuration of the FCoE NPV mode on a Nexus 5x00 switch is similar to the configuration for the Fibre Channel NPV mode. The main difference is the configuration of an Ethernet port for the ISL and the VNP port.
Use case:  FCoE NPV Configuration Between a Nexus 5000 and Nexus 7000, where we don't have native FC support on N7k.
jihicks
Hi Ridma,
On the Nexus 5548UP
Note
: Before you begin this process, you need to have  the FC_FEATURES_PKG license installed. If you  enable the FCoE feature and you do not have the license installed, it  enables a demo license for 180 days.
Cisco Nexus 5500 Storage Protocols Services License, 8 Ports
Port
N55-8P-SSK9
Fibre Channel and FCoE and FCoE NPV features supported on any 8 ports of Cisco Nexus 5548 and 5596
Cisco Nexus 5500 Storage Protocols Services License, 48 Ports
Port
N55-48P-SSK9
Fibre Channel and FCoE and FCoE NPV features supported on any 48 ports of Cisco Nexus 5548 and 5596
The information at this link should help with configuration:
http://www.cisco.com/c/en/us/support/docs/switches/nexus-5000-series-switches/116248-configure-fcoe-00.html?referring_site=smartnavRD
Best regards,
Jim
Thanks Both of you for the expalantions.
Senario that i'm referring here is.
If we have only FCoE connction between UCS and N5K and if we need to do the zoning in N5K what mode should we chooes.
