Nexus 56128P Fibre Channel Interface
jguirlinger
Hi everybody,
I'm installing a Nexus 56128P and I try to configure Fibre Channel native interface on GEM N56-M24UP2Q.
I have configured the ports to be fc interface
slot 2
port 1-24 type fc
Then i have reloaded the module, but no fc interface appeared (and no more ethernet interface 2/x).
I checked the license, i have the FC_FEATURES_PKG installed but "unused".
I guess i missed something, but can't figure out what.
Any idea ?
Julien
Walter Dey
see https://supportforums.cisco.com/discussion/12254396/fc-ports-nexus-5548up
After the port type has been changed from Ethernet to FC, the FC port will not be enabled on the switch until FCOE feature is enabled:
N5K(config)#feature FCOE
C license checked out successfully
fc_plugin extracted successfully
FC plugin loaded successfully
FCoE manager enabled successfully
FC enabled on all modules successfully
Enabled FCoE QoS policies successfully
After that, we verify that the port type is changed successfully and the FC ports appear on the switch:
N5K# show interface brief
5 Replies 5
Walter Dey
Thanks, that solved my problem !
But I don't understand why we need FCoE feature for pure FC interface, I don't need FCoE on my switch. it's at least not intuitive. What is the relationship between FC and FCoE feature ?
Julien
Hi Julien
I agree with you 100% ! and it's not well documented either.
Cheers
Walter.
Hi gents,
I've followed this post. So do you know whether the Chassis Storage License N56128-128P-SSK9  is required in order to enable FC native on some of the ports in the fixed module? I understand the license is required for enabling FCoE ..  what about for FC native only?
Your assistance is much appreciated.
Hi Fernando
Fibre Channel and FCoE Features (Requires Storage Services License)
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/data_sheet_c78-618603.html
Cisco Nexus 5500 Storage Protocols Services License, 8 Ports
Port
N55-8P-SSK9
Fibre Channel and FCoE and FCoE NPV features supported on any 8 ports of Cisco Nexus 5548 and 5596
Cisco Nexus 5500 Storage Protocols Services License, 48 Ports
Port
N55-48P-SSK9
Fibre Channel and FCoE and FCoE NPV features supported on any 48 ports of Cisco Nexus 5548 and 5596
