NPV Traffic-maps Nexus 5000
sachinraja
Level 9
Level 9
Hi All
Do you see any issues using the NPV traffic map command to  push a server's SAN traffic through specific external interface? Can  this be done online without any disruption?
for eg:
config# npv traffic-map server-interface fc1/45 external-interface fc2/14
In the case above, will the traffic automatically get distributed to  other interfaces incase fc2/14 goes down? or can we define the backup  interface statically like below:
config# npv traffic-map server-interface fc1/45 external-interface fc2/14, fc2/13
(fc2/13 is the backup interface)
Thanks & Regards
sachinraja
Level 9
Level 9
Thanks. I think I got an answer for this.
In anycase if anyone else has had any issues with traffic maps, please reply back.
what is the correct answer you came up with?
