Port-Channel MDS & UCS with a particular vsan
thomaspaget
I am having trouble setting up a  port-channel between MDS & UCS with a particular vsan. I was able to get a port-channel setup on VSAN 1 between and MDS9513 5.0(4d) and UCS 6120 XP 4.2 (1). When I try to do it with a specifc VSAN it fails. I set the VSAN on the 9513 interfaces and created the port-channel but it looks like it still wants to default to VSAN 1 when I do a  sh int. I have added the same VSAN on the UCS side as well. I have tried to see if could set the vsan on the port-channel but it doesn't look like that command is offered. Any ideas?
thomaspaget
I figured it out, I had to run the command:
vsan <#> interface port-channel 21
Hello
Having no exp of UCS switches, this may be a bit off, but....
The vsan the port channel PORTS are in is of no consequence.  The VSAN's that are allowed to traverse the trunk are the important bits.  i.e:
interface port-channel 1
  switchport trunk allowed vsan 1
  switchport trunk allowed vsan add 60
  switchport trunk allowed vsan add 80
Steven
