Ports Inventory
sanspecialist
How can I check the number of ports, ports used and free ports of an MDS switches using Fabric Manager or CLI?
I can only see from Fabric Manager the total number of ports, but I can't see how many ports are being used and how many ports are free.
Thanks.
You could also use the Fabric Manager web client (point browser to IP of the FM server) to look at the Inventory summary to see total and available ports. It's also possible to create a manual or scheduled report with the same or more detailed information.
5 Replies 5
Filiph Westman
Personally the output from "show interface brief" is enough. If you have best practice to shut unused ports you might customize (limit) the output - for an example:
# sh int br | in down
# sh int br | in "down | sfpAbsent"     (if you also have a lot of ports without SFPs)
or to show used ports
# sh int br | in up
# sh int br | in "up | trunking"       (to include trunks)
Not sure if this would be what you were looking for...
- filiph
Not really the one I'm looking. This is still kind of manual to determine how many used and unused ports there is. I'm looking for something a summary of used and unused ports. I'm looking for something that can tell me how many used ports and unused ports without having me to count it manually.
Luis Cardenas
maybe this will help...
sho interface brief | inc up | count
92
sho interface brief | inc down | count
32
sh int br | inc outOfServc | count
86
This will help as well
