Problem Nexus 5548 with FCoE + Bracade 200e + Storage SUN TEK
carmijo
Hi all, I have a problem with the integration of 2 nexus 5000 with brocade SAN Switch.
I set NPV + FCoE, but I was reading the papers for these configurations and Cisco is the question I want to create areas where I can not.
The servers are connected via Twinax with VMware directly in the UP 5048 Nexus
Someone set something like this?
greetings and thanks
Cristóbal
Prashanth Krishnappa
Hello Cristóbal
Having Nexus 5500 in NPV and MDS or Brocade as NPIV/Gateway switch is a fairly common set up. Can you explain what is not working.
Also, if you have the UP version of 5500, I suggest that you run NX-OS 5.1(3)N2(1) on it since there are couple issues
fixed in it associated with NPV.
Hello prkrishn,
the NX-OS version I have is 5.0 (3) N1 (1c), I was reading a paper and tells me I should create zones, which does not work.
I read a configuration between nexus and Dell, which has the following steps:
I can not generate areas (the latter two steps), someone has set this before?
thanks.
Cristóbal
