Question about Transmit B2B Credits
joe08091977
Hi all,
we have some HP Virtual Connect Fibre Channel Modules which are connected to MDS 9124 Switches.
The Virtual Connect Modules have 8 Buffer Credits per Port.
The output of "sho interface counters" for the ports connected to the VC´s displays:
16 receive B2B credit remaining
16 transmit B2B credit remaining
16 low priority transmit B2B credit remaining
fc1/15 is up
Transmit B2B Credit is 16
Receive B2B Credit is 16
If I understand correctly the buffer credits are communicated at flogi to the switch.
So if the VC-Modules have 8 Buffers, the Switch should display 8 transmit B2B credits  ? Right ?
Thanks for help !!
Roman Rodichev
Level 7
Level 7
Number of credits should depend on the receive frame size. If let's say you double the frame size setting, the receive B2B credit should half.
