Removing Interop Mode 1
I need to disable Interop Mode 1 after retiring McData switches. Can someone tell me what is the cli sequence to return the MDS 9000 series to default/native interop mode?
Thanks in advance!
5 Replies 5
chunkmunky
Did you set Interop Mode on a specific VSAN?
tblancha
do these commands for vsan X:
config t
vsan database
no vsan X interop 1
This will put it back in default mode.
After running the command against the vsan won't you have to suspend it to make the change active.
At one time, there was a white paper that went through a detailed migration of McData -> Cisco, including adding Cisco to the SAN in interop mode 1, and removing the McData.
I can't find it at the moment though.
I used these commands then suspened the vsan.
Worked fine.
Thanks all.
