show interface indicates 18446744073709551615 CRC, OLS, LRR, NOS
Dinjamin1
Hello Cisco,
I have seen a few cases with what appear to be bogus counter increments on multiple ports for example as follows:
fc2/15 is up
    Port description is VMAX 601194-FA08F1
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:4f:00:0d:ec:2a:11:40
    Admin port mode is F, trunk mode is off
    snmp link state traps are enabled
    Port mode is F, FCID is 0x01001f
    Port vsan is 121
    Speed is 2 Gbps
    Transmit B2B Credit is 20
    Receive B2B Credit is 16
    Receive data field Size is 2112
    Beacon is turned off
    5 minutes input rate 491910485133076760 bits/sec, 61488810641634595 bytes/sec, 61489146735798893 frames/sec
    5 minutes output rate 491912172380660848 bits/sec, 61489021547582606 bytes/sec, 61489146840890389 frames/sec
      18446744022123834516 frames input, 18446645859856220640 bytes
        0 discards, 18446744073709551614 errors
        18446744073709551615 CRC,  0 unknown class
        0 too long, 0 too short
      18446744052814023184 frames output, 18446707443362223868 bytes
        0 discards, 0 errors
      18446744073709551614 input OLS, 18446744073709551615 LRR, 0 NOS, 0 loop inits
      18446744073709551615 output OLS, 0 LRR, 18446744073709551615 NOS, 0 loop inits
      16 receive B2B credit remaining
      20 transmit B2B credit remaining
      20 low priority transmit B2B credit remaining
    Interface last changed at Wed Mar 14 23:26:10 2012
See CRC, OLS, LRR, NOS = 18446744073709551615.
This number equates to 2^64 -1. The maximum possible value of a 64-bit counter?
I would suspect a bug - any known issues or bugs?
NXOS 4.2(7d)
thanks.
dakester
It looks like a rare cosmetic issue with Gen1 linecards, which go end of support later this year. Does the problem return after clearing the counters?
looks ok after clearing
For non-Gen1 linecards, it may be this bug.
CSCud05214  Large FC interface counters
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCud05214&from=summary
Fixed in NX-OS 5.2(8) and above.
