SN5428 and Silkworm 2800
aseppala
Cisco SN 5428 v.2.3.1-K9 (fc8 gl-port, blinks green light)
Brocade Silkworm 2800 v.2.4.1c (port 15, E-port, blinks green light)
Source: "SN5428 Interoperability Whitepaper, for internal use only...)
I have done as Cisco white paper says but still Silkworm and SN5428 cannot see each other with fibrechannel and Cisco can't see any devices connected to Silkworm.
Mission impossible?
13 Replies 13
rfroom
Is the Brocade apply to see the SN5428? Please post a switchShow from the Brocade.
Silkworm:> switchshow
switchName: sw1
switchType: 2.4
switchState: Online
switchRole: Principal
switchDomain: 99
switchId: fffc63
switchWwn: 10:00:00:60:69:15:0d:b7
switchBeacon: OFF
port 0: sw In_Sync
port 1: id Online F-Port 21:00:00:e0:8b:07:ad:70
port 2: sw Online L-Port 1 public
port 3: sw Online F-Port 21:00:00:e0:8b:07:5a:70
port 4: sw Online L-Port 1 private, 8 phantom
port 5: sw Online F-Port 21:00:00:e0:8b:07:5d:70
port 6: -- No_Module
port 7: sw No_Light
port 8: -- No_Module
port 9: sw Online F-Port 21:00:00:e0:8b:06:39:90
port 10: sw Online F-Port 21:00:00:e0:8b:07:ae:70
port 11: sw Online F-Port 10:00:00:00:c9:2e:c9:88
port 12: sw Online F-Port 10:00:00:00:c9:2e:c5:8d
port 13: id No_Light
port 14: -- No_Module
port 15: sw Online E-Port (unknown)
Port 15 is connected to the Cisco fc8...And I have tried to change port/module/cables. Brodade will show some traffic between ports,
Brocade Port Informatiom
4-byte Word Transmited: 61117548
4-byte Word Recieved: 1395351
Frames Transmitted: 5093125
Frames Reveived: 106
C2 Rames: 0
C3 Frames Received: 90
Link Control Frames: 8
portlogshow
Oct 18 task event port cmd args
00:12:04.216 tReceive loopscn 0 LIP f7f7
00:12:04.216 tTransmit Tx3 0 12 22000000,00000000,ffffffff,11010000
00:12:06.333 tReceive loopscn 0 TMO 11010000
00:12:06.333 tReceive loopscn 0 LIP 8001
00:12:06.333 tReceive loopscn 0 LIP f7f7
00:12:06.333 tTransmit Tx3 0 12 22000000,00000000,ffffffff,11010000
00:12:08.449 tReceive loopscn 0 TMO 11010000
00:12:08.449 tReceive loopscn 0 LIP 8001
00:12:08.449 tReceive loopscn 0 LIP f7f7
00:12:08.449 tTransmit Tx3 0 12 22000000,00000000,ffffffff,11010000
00:12:10.566 tReceive loopscn 0 TMO 11010000
00:12:10.566 tReceive pstate 0 LF2
00:12:12.099 tFcph loopscn 0 LIP 8001
00:12:12.099 tReceive loopscn 0 LIP f7f7
00:12:12.099 tTransmit Tx3 0 12 22000000,00000000,ffffffff,11010000
00:12:14.199 tReceive loopscn 0 TMO 11010000
00:12:14.199 tReceive loopscn 0 LIP 8001
00:12:14.199 tReceive loopscn 0 LIP f7f7
00:12:14.199 tTransmit Tx3 0 12 22000000,00000000,ffffffff,11010000
Portlogdump
00:22:26.583 tTransmit Tx3 0 12 22000000,00000000,ffffffff,11010000
00:22:28.699 tReceive loopscn 0 TMO 11010000
00:22:28.699 tReceive loopscn 0 LIP 8001
00:22:28.699 tReceive loopscn 0 LIP f7f7
00:22:28.699 tTransmit Tx3 0 12 22000000,00000000,ffffffff,11010000
00:22:30.816 tReceive loopscn 0 TMO 11010000
00:22:30.816 tReceive pstate 0 LF2
00:22:32.349 tFcph loopscn 0 LIP 8001
00:22:32.349 tReceive loopscn 0 LIP f7f7
00:22:32.349 tTransmit Tx3 0 12 22000000,00000000,ffffffff,11010000
00:22:34.466 tReceive loopscn 0 TMO 11010000
00:22:34.466 tReceive loopscn 0 LIP 8001
00:22:34.466 tReceive loopscn 0 LIP f7f7
00:22:34.466 tTransmit Tx3 0 12 22000000,00000000,ffffffff,11010000
Brocade can't see Cisco and Cisco can't Brocade.
I tried in Brocade add manually Cisco WWN (all WWNs) addresses but Brocade still can't see Cisco.
From Cisco:
Domain ID 100
Error Detect Timeout 2000
Domain ID lock True
Resource Allocation Timeout 10000
Buffer to Buffer Credit 12
Zoning Merge Brocade
Node WWN 100000065338cf01
Zoning Default All
Initiator WWPN1 280000065338cf00
Zoning Autosave True
Initiator WWPN2 290000065338
Active Zone 23
mrfrase
Blinking light still says the fabrics are segmented for reasons of timers not matched, zoning not configured correctly or cable issue. portlogShow and portLogDump on the brocade can give you the reason for the segmentation.
Can you set the Zoning Merge to SW2
interface fc zoning merge sw2
Then capture a :
show interface fc
Thanks, Mike
switch3]# int fc zoning merge sw2
switch3]# show interface "fc8"
Operational Data
Interface Stat IP/Netmask MAC Options
fc8 down type Fibre Channel
OperState disabled
PortID 640800
WWN 200800065338cf01
LinkSpeed 1Gb/s
LinkState Active
SyncState SyncAcquired
LoginStatus NotLoggedIn
Loopback Status Not Runnin
MaxCredit 12
RunningType e-port
PendingType gl-port
SFPType xxx-xx-xx-x
SFPVendor CISCO-TYCO
SFPVendorID 764000
SFPPartNumber 1511168-1
SFPRev 0000
Configuration Data
Al- Fan- Link Loopback Mfs- Time Port- Port-
Interface Status fairness enable speed type bundle out type mode
fc8 enabled disabled enabled 1Gb/s Unknown enabled 10 gl-port
mrfrase
I am am trying to locate a 2800 switch to test with.
I need you to do a couple more items for me.
Can you change the link speed on the SN5428 to 1 gb
int fc1 linkspeed 1gb
Also can I have a show log off the sn5428
black.scott
i am having the exact same problem. I am using compaq el16 which are just rebadged brocades. They told me to change my domain id's to above 97. My storage works guys tell me that we will loose all 300 connections definded on the 10 controllers we have. Any suggestions?
What do you mean by same problem. Connecting a Compaq switch to a SN5428? Or connecting a Brocade 2800 to a Compaq? Is it Compaq telling you to change the Domain ID
I am connected a compaq switch to a sn5428. Cisco via the white paper and tac have told me to change the domain is to above 97. Problem is Compaq tells me this changes WWN address and call my defined connections will have to be redefined. Major issue in a production envirment. Any advice?
I agree, it is to bad Brocade has this type of limit with Domain addresses when it comes to connecting non Brocade Switches to the network but is the way they have implemented FC-SW2, this selection of domain numbers is not the choice of the SN5428 . For what it is worth the MDS switches do not have this type of restricted Domain numbering use when connecting unlikt switches to the fabric.
You should try using a Nishan switch as it has no problem connecting to Brocades 28xx and 38xx switches. www.nishansystems.com.
efrahim
Level 4
Level 4
Hopefully the following link will be helpful . I just tried it in the lab and it worked.
http://www.cisco.com/warp/public/cc/pd/rt/5420/ps2162/prodlit/fibre_ds.htm
Original problem discription stated user had followed the instructions from this link. I have since tested the SN5428 connected to a Brocade 2800 and I had no problems.
