SNMP TRAPS
ronencn1012
I want to config snmp traps from my new mds9513 to SCOM
i configured the destination in Device Manager , and when i try to test it , we pool out one FC Port and got the Link Down Message
And when i Try to reset one Module i want to get an snmp trap and call home mail , but it's not working.
1. how do i have to setup this environment?
2. how can i get TRAP with Port Description insted of Link Failure %port....
Ronen
emcprateek_2
Hello Ronen,
Are you resetting the module gracefully (ie using CLI to reset) ?
Call home will not be generated in case you reload the module using CLI. Instead try re-seating the module physically.
Prateek
Thanks for answering my question , when i  took  the module  out physically
it sent the trap/callhome .
how can i get callhome message with port discription insted of %port....when link goes up/down ?
Thanks ,
Ronen
