Some problem about FCoE with N7000
xieyida99
Hello every one !
     I`m a Network guy and I think I`m a fresh for storage. I`m config a FCoE link on Nexus 7000,but there is something wrong and I need some help from you !
     Problem:
         1. I can built a storage VDC , but I can`t enable " feature fcoe " , but "feature-set fcoe" is okay
         2. when cheak interface status ,It appear :
xxxxxxxx# show int e3/39
Ethernet3/39 is down (Internal-Fail errDisable, fcoe_mgr: ethernet interface module is not licen)
         my software version is 6.1.2 and line-card is N7K-F248XP-25E ,and is my license:
xxxxxxxx# show license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
MPLS_PKG                      Yes   -   Unused Never       -
STORAGE-ENT                   Yes   -   Unused Never       -
VDC_LICENSES                  No    0   Unused             -
ENTERPRISE_PKG                No    -   Unused             -
FCOE-N7K-F132XP               No    0   Unused             -
FCOE-N7K-F248XP               No    0   Unused             -
ENHANCED_LAYER2_PKG           Yes   -   In use Never       -
SCALABLE_SERVICES_PKG         Yes   -   Unused Never       -
TRANSPORT_SERVICES_PKG        Yes   -   Unused Never       -
LAN_ADVANCED_SERVICES_PKG     Yes   -   In use Never       -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   Unused Never       -
It is a license problem ?  Please help me ,Thanks Very much!
I think you can use the grace license first to ensure your configuration will run correctly.
issue command license grace on the N7K, and then try to enable the fcoe license on the F module (license fcoe module x). The FCoE only run on the F module. If use F2 module, you must have sup 2.
5 Replies 5
gkumark
Please confim below things.
1. On the switch make sure that fcoe feature-set is isnatlled -
install feature-set fcoe
2. Make sure that, you have allowed fcoe feature-set for the storage vdc
conf t
vdc
allow feature-set fcoe
3. Make sure that the module you are using is licensed for FCoE
conf t
license fcoe module
Hope this helps.
-Ganesh
Thank you for your answer !
     I have installed feature-set and allow it in storage VDC , but when I  license fcoe module
switch(config)# license fcoe module 3
ERROR:  FCOE License not available XXG_Nexus7004(config)# license fcoe module 3
Does it mean I have no license for module ?
Yes, looks like you don't have the FCoE license installed on the switch. Could you please check if you have FCoE License installed using the command, show license file
This would show what kind of license each file is and hence you can check if you have one for FCoE.
-Ganesh
xieyida99
Thanks for all !
I will try later and find out what the problem is , Thank you for all resolves above !
