TACACS+ AAA configuration on MDS 9222i
Andrew Bailey
I am not NX-OS guy... but and I am trying to configure authentication with our ACS on our MDS 9222i. I want to use tacacs+ then local if that fails.
In IOS I can do that with the following command:
aaa authentication login default group tacacs+ local
But in NX-OS that is not an option.
hostname(config)# aaa authentication login default group servergroupname ?
  <CR>
  WORD   Server group name (Max Size 127)
  none   No authentication
Here is my config
feature tacacs+
tacacs-server key password
tacacs+ distribute
tacacs-server host x.x.x.x
tacacs+ commit
aaa group server tacacs+ servergroupname
tacacs-server directed-request
I want to be able to use both tacacs+ and local user database for authentication? What am I missing?
Vu Phan
If you want to use both tacacs and local for authentication.  You will need to create local users on the switch.
The authentication will first check with tacacs then fall-back to local.
Vu Phan
Thanks for your response. I originally wanted to use both tacacs+ and local, but I am ok with having local only work when tacacs+ is unreachable.
