The FC Cisco Switch is not recognizing the SFP from storage
P.manhique
I am trying to connect a  SAN switch to a storage but the  Switch is not recognizing the SFP from storage. Are there any compatiility issues?
Details of the storage SFP:
Model Cisco Tyco
Model of Switch: MDS9148
7 Replies 7
Walter Dey
Don't understand; do you have problems with the SFP on the MDS, or the peer side on the storage controller side ?
https://supportforums.cisco.com/discussion/12736436/cisco-5548-version-52-equivalent-command-service-unsupported-transceiver
I am having the problem at the MDS side. Below is the error i am having:
fc1/13 sfp is present but not supported
    Name is CISCO-TYCO
    Name is CISCO-TYCO
    Manufacturer's part number is 1-2053783-2
    Revision is T
    Serial number is TED1923B5HS
    FC Transmitter type is Unknown(0)
    FC Transmitter supports Unknown(0) link length
    Transmission medium is Unknown(0)
    Supported speeds are - Min speed: -1 Mb/s, Max speed: -1 Mb/s
    Nominal bit rate is 10300 Mb/s
Looks odd ! nominal bit rate 10300 Mb/s ! this is 10G !
MDS 9148 is a classical FC switch ?
Yes it is..!!
type is SFP-H10GB-CU3M
This is a copper 10G Ethernet cable.
Use one of these SFPs:
Cisco MDS 9000 Family Pluggable Transceivers Data Sheet
David
Are you sure this is a FC SFP ? 4, 8 G ?
If yes, try to use the "service unsupported-transceiver" which is a hidden command (type the full command, no abbreviation).
