Trunk link inactive
grant.maynard
Level 4
Level 4
I have two (new) 9706 with a trunk (multi-VSAN) link between them. Nothing else is connected so all VSANs are inactive.
My question is, would you expect the trunk link to be up or inactive? It is inactive.
Thanks in advance.
2 Accepted Solutions
Did you try assigning any arbitrary port to one of your inactive VSANs (your 10-13)? Perhaps assigning the ports in the port-channel might work. I see from your recent output/post that the port-channel ports are on VSAN 1.
Very good ! so the suspended vsan 1 was causing the Problem; now you can proceed with the port channel and everything should be ok !
14 Replies 14
Walter Dey
Have you setup trunk according to
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_3_x/configuration/guides/fm_3_3_1/trnk.html
Can you please post some more information.
I have this:
version 7.3(1)DY(1)
feature fport-channel-trunk
interface port-channel11
  channel mode active
  switchport mode E
  switchport trunk allowed vsan 10-13
  switchport description san-coresw-09
  switchport rate-mode dedicated
interface fc1/3
  switchport description san-coresw-09 fc1/3
  channel-group 11 force
  no shutdown
Please provide the output of the following commands
show port-channel compatibility-parameters
show port-channel summary
show port-channel database
show port-channel consistency detail
show port-channel usage
show interface
show interface trunk
show trunk protocol
mds9706-a1# show port-channel compatibility-parameters
Parameters that have to be consistent across all members in a port-channel.
1. physical port layer
Members must have the same interface type, such as fibre channel, ethernet
or fcip.
2. port mode
Members must have the same port mode configured, either E,F or AUTO. If
they are configured in AUTO port mode, they have to negotiate E or F mode
when they come up. If a member negotiates a different mode, it will be
suspended.
3. trunk mode
Members must have the same trunk mode configured. If they are configured in
AUTO trunking mode, they have to negotiate the same trunking mode when they
come up. If a member negotiates a different mode, it will be suspended.
4. speed
Members must have the same speed configured. If they are configured in AUTO
speed, they have to negotiate the same speed when they come up. If a member
negotiates a different speed, it will be suspended.
5. MTU
Members have to have the same MTU configured. This only applies to ethernet
port-channel.
6. ethernet port index
This only applies to ethernet port-channel. Each ethernet port-channel
could only have two ethernet ports. They must be in the same slot, their
port indeces must be adjacent and the lower number must be odd. Example:
Gigabitethernet 8/5 - 6.
7. rate mode
Members must have the same rate mode configured. Rate Mode applies only to
isola FC ports
8. Maximum Speed Mismatch
Members must be configured to auto-negotiate to the same maximum speed.
9. Resources Unavailable
Members must be able to acquire resources required to maintain
compatibility. Check shared resources like speed, rate-mode and port mode.
10. Out of Service
Members must be in-service.
11. MEDIUM
Members have to have the same medium type configured. This only applies to
12. Span mode
Members must have the same span mode.
13. admin channel mode
Port Channel admin channel mode must be active.
14. load interval
Member must have same load interval configured.
15. span port headers
The exclude header span config must either be present or absent on all
members.
16. port VSAN
Members must have the same port VSAN.
17. port allowed VSAN list
Members must have the same port allowed VSAN list.
18. IP address
Members must not have IP address configured. This only applies to ethernet
port-channel.
19. IPv6 configuration
Members must not have any IPv6 configuration. This only applies to ethernet
port-channel.
20. port-security active bindings
Members must all be permitted by the activated port-security bindings and
fabric-bindings in all the allowed VSANs.
21. FC receive buffer size
Members must have the same fc receive buffer size. If the configured
receive buffer size is not compatible with the port capability then the
port will be error disabled
22. physical port layer
or fcip.ILC ports cant be part of bundle
23. port mode
suspended.
24. port mode
On NPV switch allow only NP,TNP ports to be part of port-channel. Do not
allow F ports to be part of port-channel on NPV.
25. port mode
Config compat check failed.
26. Bundle is Isola 4G and Member i
27. Port Speeds not compatible Norm
28. Port type and Physical layer ar
Ports must be configured to the same physical layer.
29. Port type is not valid
Port types must be checked.
30. Port mode not matching
Port mode is TE and ref port mode is E
31. Cap check failed for OSM port
Cap check failed for OSM port and cannot be added to port channel
32. Admin compat check fail
Admin compat check failed for port mode TL and FL
33. Admin compat check fail
Admin compat check failed for port mode F
34. Admin FEC state
Members must have the same admin FEC state configured
35. Admin FEC TTS state
Members must have the same admin FEC tts state configured
36. Admin max NPIV limit
Members must have same max NPIV limit configured
37. Admin max NPIV limit for trunk
Members must have same trunk max NPIV limit configured
38. IP ACLs
Members must not have IP ACLs configured individually on them. This only
39. sub interfaces
Members must not have sub-interfaces.
40. Duplex Mode
Members must have same Duplex Mode configured.
41. Ethernet Layer
Members must have same Ethernet Layer (switchport/no-switchport) configured.
42. Span Port
Members cannot be SPAN ports.
43. Storm Control
Members must have same storm-control configured.
44. Flow Control
Members must have same flowctrl configured.
45. Capabilities
Members must have common capabilities.
46. Capabilities speed
Members must have common speed capabilities.
47. Capabilities duplex
Members must have common speed duplex capabilities.
48. rate mode
49. Capabilities FabricPath
Members must have common fabricpath capability.
50. Port has PVLAN config
Members must have same pvlan configuration
51. 1G port is not capable of actin
Members must be 10G to become part of a vPC peer-link.
52. EthType
Members must have same EthType configured.
53. shared interface
Members can not be shared-interfaces.
54. Capabilities SpanDest
Members must be capable of span destination configuration
55. Module Type Incompatible
Module type for interfaces is not compatible.
56. Port Mode Fabricpath Incompatib
Members are Fabricpath Enforce locked, not compatible.
57. Rewrite Translate - Rate Mode s
Members have rate mode shared,and rewrite translate exists on the channel
group,Not compatible.
58. FEX - PVLAN promiscuous config
FEX ports cannot have private VLAN promiscuous or promiscuous trunk configs
59. vmtracker enable mismatch
Members have vmtracker enable mismatch
60. port
Members port VLAN info.
61. port
Members port does not exist.
62. switching port
Members must be switching port, Layer 2.
63. port access VLAN
Members must have the same port access VLAN.
64. port native VLAN
Members must have the same port native VLAN.
65. port allowed VLAN list
Members must have the same port allowed VLAN list.
66. VLAN translation mapping list
Members must have the same VLAN translation list.
67. Members should have same fex co
Members must have same FEX configuration.
68. FEX pinning max-links not one
FEX pinning max-links config is not one.
69. Multiple port-channels with sam
Multiple port-channels to same FEX not allowed.
70. Pinning Params
Members must have the same pinning parameters.
71. All HIF member ports not in sam
All HIF member ports not in same pinning group
72. Slot in host vpc mode
Cannot add cfged slot member to fabric po vpc.
73. Members in multiple FEX
Members must belong to same FEX.
74. Members are of different type
Members must of same interface type.
75. port egress queuing policy
10G port-channel members must have the same egress queuing policy as the
port-channel.
76. Port Security policy
Members must have the same port-security enable status as port-channel
77. Port priority-flow-control
PFC config should be the same for all the members
78. Dot1x policy
Members must have host mode as multi-host with no mab configuration. Dot1X
cannot be enabled on members when Port Security is configured on port
channel
79. fcsp mode
Members must have the same fcsp mode
80. fcsp esp parameters
Members must have the same fcsp esp parameters
81. PC Queuing policy
Queuing policy for Non-DCE PC should be non-dce
82. PC Queuing policy
Queuing policy for the PC should be same as system queuing policy
83. PVLAN port config
Members must have same PVLAN port configuration.
84. Emulated switch port type polic
vPC ports in emulated switch complex should be L2MP capable.
85. VFC bound to port
Members cannot have VFCs bound to them.
86. VFC bound to port channel
Port Channels that have VFCs bound to them cannot have more than one member
87. VFC bound to FCoE capable port
Port Channels that have VFCs bound to them cannot have non fcoe capable
member
88. VFC bound to FCoE capable port
Port Channels that have VFCs bound to them cannot have non fcoe licensed
member
89. EVC EFP configured under port c
Port Channel members cannot have EVC EFP configured under them
90. Fex ports for span
Port-Channel is already a SPAN source. Cannot add FEX ports connected
through F2/F2E series line cards to this PC
91. shut lan
Members cannot have shut lan configured
92. VPC orphan port suspend configu
Port channel members cannot have vPC orphan port suspend configured under
them
93. tag native
Members must have same native vlan tagging configured
94. VNSEG VSI configured under port
Port Channel members cannot have VNSEG VSI configured under them
95. VNSEG VSI Id for FEX > 62
VNSEG VSI Id greater than 62 not allowed on FEX Ports
96. VNSEG VSI configured under port
VNSEG VSI configured under port channel and VSI under FEX member should not
have overlapping mappings
97. VNSEG VSI Id and profile name m
FEX Port Channel members and port-channel configuration for VSI Id and
profile name should match
98. VNSEG VSI type mismatch on FEX
All FEX ports should have same VSI Type - STATIC/VDP/DFS
99. PLSM EDP port type policy
EDP ports should fail to be part of Port Channel
100. Port priority-flow-control long
PFC_LD config should be the same for all the members
101. Port channel LFC-PFC compat che
PFC of PC to be turned OFF when LFC is ON or LFC of PC to be default, to
add DCE member
102. CTS mode
Members must have the same CTS mode configured (either "cts manual" or "cts
dot1x" or no cts)
103. CTS SGT propagation
SGT propagation must either be enabled or disabled on all members
104. CTS SGT policy
Members must all have either "policy static" or "policy dynamic" or no
policy configured
105. CTS peer identity
Members must all have the same peer identity configured
106. CTS SGT configuration
Members must all have the same SGT configured
107. CTS replay protection
Replay protection must either be enabled or disabled on all members
mds9706-a1#show port-channel summary
Interface                 Total Ports        Oper Ports        First Oper Port
port-channel 10                4                 0                  --
port-channel 11                2                 0                  --
mds9706-a1# show port-channel database
port-channel10
    Administrative channel mode is active
    Operational channel mode is active
    Last membership update succeeded
    4 ports in total, 0 ports up
    Ports:   fc1/1    [down]
             fc1/2    [down]
             fc1/13   [down]
             fc1/14   [down]
port-channel11
    2 ports in total, 0 ports up
    Ports:   fc1/3    [down]
             fc1/15   [down]
mds9706-a1#show port-channel consistency detail
Authoritative port-channel database:
total 2 port-channels
port-channel 10:
    4 ports, first operational port is none
    fc1/14   [down]
    fc1/13   [down]
    fc1/2    [down]
    fc1/1    [down]
port-channel 11:
    2 ports, first operational port is none
    fc1/15   [down]
    fc1/3    [down]
database 1: from module 1
port-channel 10:
    fc1/13   [down]
    fc1/14   [down]
    fc1/1    [down]
    fc1/2    [down]
port-channel 11:
    fc1/15   [down]
    fc1/3    [down]
mds9706-a1#show port-channel usage
Totally 2 port-channel numbers used
Used  :   10 - 11
Unused:   1 - 9 , 12 - 256
mds9706-a1# show interface fc1/3
fc1/3 is down (Inactive)
    Port description is san-coresw-09 fc1/3
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:03:00:de:fb:43:39:00
    Admin port mode is E, trunk mode is on
    snmp link state traps are enabled
    Port vsan is 1
    Receive data field Size is 2112
    Beacon is turned off
    Belongs to port-channel11
    5 minutes input rate 0 bits/sec,0 bytes/sec, 0 frames/sec
    5 minutes output rate 0 bits/sec,0 bytes/sec, 0 frames/sec
      4 frames input,304 bytes
        0 discards,0 errors
        0 invalid CRC/FCS,0 unknown class
        0 too long,0 too short
      4 frames output,304 bytes
        0 discards,0 errors
      0 input OLS,0  LRR,0 NOS,0 loop inits
      0 output OLS,0 LRR, 0 NOS, 0 loop inits
    Last clearing of "show interface" counters  :never
mds9706-a1# show interface trunk
Port          Native  Status        Port
              Vlan                  Channel
Port          Vlans Allowed on Trunk
Port          STP Forwarding
Port          Vlans in spanning tree forwarding state and not pruned
Port          Vlans Forwarding on FabricPath
mds9706-a1# show trunk protocol
Trunk Protocol is enabled
mds9706-a1#
Do you have fibre optic cables connected between the 2 MDS ?
I see that all fc interfaces are down !
can you please enable them all
Conf t
Interface fc 1/3
no shut
This is MM fibre, 16G.
Physical interface is enabled - does Port-Channel need to be too?
Config is:
  channel mode active
  switchport mode E
interface fc1/3
  no shutdown
Yes, you Need to "no shut" the port channel as well
Just tried that, it hasn't helped.
We have mds9706-a1 ---- TE link ----- mds9706-a2.
It seems like a chick-and-egg situation - the trunk link carries 4 VSANs which are all inactive because no devices are connected, and this makes the trunk link inactive. But if the trunk link was up then the VSANs would be up?
Can you spoof an interface up like in ethernet world (no keepalive)?
mds-9706-a1(config)# int po10
mds-9706-a1(config-if)# no shut
mds-9706-a1(config-if)# int po11
mds-9706-a1(config-if)# end
mds-9706-a1# copy run start
[########################################] 100%
Copy complete.
mds-9706-a1# sh int port 11
port-channel11 is down (No operational members)
    Port WWN is 24:0b:00:de:fb:43:39:00
    Port vsan is 1
      8 frames input,608 bytes
        0 discards,0 errors
      8 frames output,608 bytes
        0 discards,0 errors
    Member[1] : fc1/3
    Member[2] : fc1/15
mds-9706-a1# sh int fc1/3
    Port vsan is 1
        0 discards,0 errors
        0 discards,0 errors
mds-9706-a2(config)# int po10
mds-9706-a2(config-if)# no shut
mds-9706-a2(config-if)# int po11
mds-9706-a2(config-if)# end
mds-9706-a2# copy run start
Copy complete.
mds-9706-a2# sh int po11
    Port description is san-coresw-07
    Port WWN is 24:0b:00:de:fb:43:32:00
    Port vsan is 1
        0 discards,0 errors
        0 discards,0 errors
    Member[1] : fc1/3
    Member[2] : fc1/15
mds-9706-a2# sh int fc1/3
    Port description is san-coresw-07 fc1/3
    Port WWN is 20:03:00:de:fb:43:32:00
    Port vsan is 1
        0 discards,0 errors
        0 discards,0 errors
After having turned on pc, try to shut / unshut each interface !
Do you see any Errors: show logging log
If this doesn't help delete the pc, and see if the fc links are working or not.
No luck - removed from port-channel with shut/no shut - physical link is still inactive.
If all VSANs are inactive, would you expect the TE to be inactive too?
Can i somehow spoof a VSAN to be up?
Thanks for your persistence!
mds9706-a1# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
mds9706-a1(config)# int fc1/3
mds9706-a1(config-if)# shut
mds9706-a1(config-if)# no channel-group 11 force
fc1/3 removed from port-channel 11 and disabled
please do the same operation on the switch at the other end of the port-channel
fc1/3: not part of port-channel
mds9706-a1(config-if)# switchport mode E
mds9706-a1(config-if)# switchport trunk allowed vsan 10-13
Warning: This command will remove all VSANs currently being trunked and trunk only the specified VSANs.
Do you want to continue? (y/n) [n] y
mds9706-a1(config-if)# no shut
mds9706-a1(config-if)# end
mds9706-a1# sh int fc1/3
    Port vsan is 1
        0 discards,0 errors
        0 discards,0 errors
On 172.31.217.115
mds9706-a2# conf t
mds9706-a2(config)# interface fc1/3
mds9706-a2(config-if)# shut
mds9706-a2(config-if)# no channel-group 11 force
mds9706-a2(config-if)# switchport mode E
mds9706-a2(config-if)# switchport trunk allowed vsan 10-13
mds9706-a2(config-if)# no shut
mds9706-a2(config-if)# end
mds9706-a2# sh int fc1/3
    Port vsan is 1
        0 discards,0 errors
        0 discards,0 errors
Your ports are in vsan 1, most likely vsan 1 is suspended !
Create a new vsan different from 1, and put all your PC interface and PC member interface into this vsan
Using vsan 1 is not recommended and not best practise; any unused interface by default is in vsan 1. Therefore a "show vsan database Membership"  would show you any free interfaces in vsan 1
We weren't going to use vsan 1 and had "vsan 1 suspend" under the vsan database.
I took the physical (fc1/3) out of the port-channel and assigned it to one of the trunked vsans and it looks like the link has come up:
mds9706-a1# conf t
mds9706-a1(config)# vsan database
mds9706-a1(config-vsan-db)# vsan 10 interface fc1/3
mds9706-a1(config-vsan-db)# exit
mds9706-a1(config)# end
fc1/3 is trunking
    Peer port WWN is 20:03:00:de:fb:43:32:00
    Port mode is TE
    Port vsan is 10
    Speed is 16 Gbps
    Rate mode is dedicated
    Transmit B2B Credit is 500
    Receive B2B Credit is 500
    B2B State Change Number is 14
    admin fec state is down
    oper fec state is down
    Trunk vsans (admin allowed and active) (10-13)
    Trunk vsans (up)                       (10-13)
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             ()
    5 minutes input rate 1824 bits/sec,228 bytes/sec, 2 frames/sec
    5 minutes output rate 1824 bits/sec,228 bytes/sec, 2 frames/sec
      784 frames input,65416 bytes
        0 discards,0 errors
      784 frames output,64620 bytes
        0 discards,0 errors
      1 input OLS,1  LRR,1 NOS,0 loop inits
      1 output OLS,1 LRR, 0 NOS, 0 loop inits
      500 receive B2B credit remaining
      500 transmit B2B credit remaining
      500 low priority transmit B2B credit remaining
    Interface last changed at Fri Aug  4 15:41:26 2017
mds9706-a1# show vsan membership
vsan 1 interfaces:
    fc1/1             fc1/2             fc1/4             fc1/5
    fc1/6             fc1/7             fc1/8             fc1/9
    fc1/11            fc1/12            fc1/13            fc1/14
    fc1/15            fc1/16            fc1/17            fc1/18
    fc1/19            fc1/20            fc1/21            fc1/22
    fc1/23            fc1/24            fc1/25            fc1/26
    fc1/27            fc1/28            fc1/29            fc1/30
    fc1/31            fc1/32            fc1/33            fc1/34
    fc1/35            fc1/36            fc1/37            fc1/38
    fc1/39            fc1/40            fc1/41            fc1/42
    fc1/43            fc1/44            fc1/45            fc1/46
    fc1/47            port-channel10    port-channel11
vsan 10 interfaces:
    fc1/3             fc1/10            fc1/48
vsan 11 interfaces:
vsan 12 interfaces:
vsan 13 interfaces:
vsan 4079(evfp_isolated_vsan) interfaces:
vsan 4094(isolated_vsan) interfaces:
mds9706-a2# conf t
mds9706-a2(config)# vsan database
mds9706-a2(config-vsan-db)# vsan 10 interface fc1/3
mds9706-a2(config-vsan-db)# exit
mds9706-a2(config)# end
mds9706-a2# show int fc1/3
fc1/3 is trunking
    Peer port WWN is 20:03:00:de:fb:43:39:00
    Port mode is TE
    Port vsan is 10
    Speed is 16 Gbps
    5 minutes input rate 1792 bits/sec,224 bytes/sec, 2 frames/sec
      770 frames input,63860 bytes
        0 discards,0 errors
      770 frames output,64412 bytes
        0 discards,0 errors
      0 input OLS,1  LRR,0 NOS,0 loop inits
mds9706-a2# show vsan membership
vsan 1 interfaces:
vsan 10 interfaces:
    fc1/3             fc1/10            fc1/48
vsan 11 interfaces:
vsan 12 interfaces:
vsan 13 interfaces:
