Upgrading from NX-OS 6.2(3) to 7.3.1.d1.1 on an MDS 9513
Ahmed Abdullahi
Hello everyone,
I am trying to perform an upgrade on a MDS 9513 that is currently running 6.2(3) and I want to upgrade to  7.3.1.D1.1.
when I run the 'show install all impact' command to check on how the upgrade will get I get the following:
Compatibility check is done:
Module bootable Impact Install-type Reason
1 yes disruptive reset Incompatible image
2 yes disruptive reset Incompatible image
3 yes disruptive reset Incompatible image
4 yes disruptive reset Incompatible image
5 yes disruptive reset Incompatible image
6 yes disruptive reset Incompatible image
7 yes disruptive reset Incompatible image
8 yes disruptive reset Incompatible image
9 yes disruptive reset Incompatible image
10 yes disruptive reset Incompatible image
11 yes disruptive reset Incompatible image
12 yes disruptive reset Incompatible image
Can you tell me,
  1. Does this mean that the upgrade will cause an outage?
  2. Is there someway from my to avoid this, perhaps by upgrading to an intermediary NX-OS version?
  3. What does 'incompatible image' mean?
Also, not related to this upgrade, but what does a install type: rolling mean?  Does a rolling install type cause a module to stop passing traffic?
Ahmed
2 Accepted Solutions
Manish Gogna
Hi Ahmed,
Couple of links that you can reference
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/7_3/release_notes/mds_nxos_rn_7_3.html#pgfId-1104892
Table 2 Nondisruptive Upgrade Path to Cisco MDS NX-OS Release 7.3(1)DY(1)
Current Release
Nondisruptive Upgrade Path and Ordered Upgrade Steps
MDS NX-OS:
7.3(0)DY(1)
Upgrade to MDS NX-OS Release 7.3(1)DY(1)
7.3(1)D1(1)
1. Downgrade to MDS NX-OS Release 7.3(0)D1(1)
2. Upgrade to MDS NX-OS Release 7.3(1)DY(1)
All 6.2(9) and above releases
Upgrade directly to MDS NX-OS Release 7.3(1)DY(1)
All 6.2(7) and earlier 6.2(x) releases
1. Upgrade to MDS NX-OS Release 6.2(9)
and
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/7_3/upgrade/upgrade.html#pgfId-588866
Manish
- Do rate helpful posts -
Rolling upgrade means zero downtime. You would see this typically with non-supervisor  module.
5 Replies 5
Manish Gogna
Hi Ahmed,
Current Release
MDS NX-OS:
7.3(0)DY(1)
7.3(1)D1(1)
and
Manish
Hi Santkumd528,
You mean, zone downtime, all the ports will continue to pass traffic even as the module is being upgraded?
zero downtime = no downtime
Thank you santkumd528 and Manish Gogna .
