Use VIC card connect on Cisco UCS connect direct to Storage
ssokneang
Dear Forum,
I have 1 UCS Server C240 with VIC card installation, i would like to connect VIC using iSCSI or FC connect to Storage buy Direct connect from server to Storage, but the vNIC in VIC card shown that it is not up, is there anyway that can connect form Server to Storage without FI Switch? please kindly advise. thank
Manish Gogna
Looking at the design / config guides available i don't see an option to do so, you may check the following links as a reference
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-manager/110202-lan-san-connectivity-ucs.html
https://supportforums.cisco.com/document/30791/understanding-and-deploying-ucs-b-series-storage-area-networking
Manish
- Do rate helpful posts -
