VFC x is trunking. no way to set the host connecting through FCoE
eric.krejci
I have a Nex 5548 version 5.0(3)N1(1b)
at this time release to configure FCoE was simply the steps of mapping VLAN to VANS, creating vfc and adding the vfc to the good vsan..
now I'm stuck.
I've my interface Eth in a PO. I bound the vfc to this po. and when the server boot up, I simply have the vfs stuck in "vfc x is trunking".
sho inter vfc 1258
vfc1258 is trunking
Bound interface is port-channel1258
Port description is "esx58 FAB2"
Hardware is Virtual Fibre Channel
Port WWN is 24:e9:00:05:73:cd:70:ff
Admin port mode is F, trunk mode is on
snmp link state traps are enabled
Port mode is TF
Port vsan is 2
Trunk vsans (admin allowed and active) (2)
Trunk vsans (up)                       ()
Trunk vsans (isolated)                 ()
Trunk vsans (initializing)             (2)
1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
0 frames input, 0 bytes
0 discards, 0 errors
0 frames output, 0 bytes
last clearing of "show interface" counters never
Interface last changed at Mon Apr 11 17:23:02 2011
a cannot turn off the trunk mode of the vfc.
let me show you the vfc conf:
interface vfc1258
bind interface port-channel1258
switchport trunk allowed vsan 2
switchport description "esx58 FAB2"
no shutdown
honestly when i run these conf against a Nex 5010 in rev 4.2 it was working straitforward. how can I set this vfc to F mode only?
hope you will help me.
thanks in advance.
Eric
5 Replies 5
Kris Vandecruys
Hi eric,
this should be as simple as
# conf term
(config)# interface vfc 1258
(config-if)# no switchport trunk allowed vsan all
(config-if)# end
Nice try, but I got this on both host interfaces:
vfc1258 is down (Isolation due to no common vsans with peer on trunk)
Port description is "ditex-esx58 FAB2"
Port vsan is 2
Interface last changed at Mon Apr 11 19:39:17 2011
Eric
Hi Eric
Did you find a solution on this ? I'm having the exact same issue and I have tried just about anything.
Tnx
Claus
Sorry about the delay.
this was related to the fact the Cisco doesn't enable by default the QOS for FCoE on their nes Nexus 55xx switches.
enabling the proper QOS for FCoE can be found on the following page:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/troubleshooting/guide/n5K_ts_fcoe.html#wp1037424
once done you vfc will come up.
Eric
I have the same problem, when running 5.2(1)N1(1). The adapter is an LP21002-C, which is a Generation 2 CNA configured as a "Fabric point to point" interface on the Emulex side.
We've tried setting the QoS as explained in the parent post, to no avail.
When connected to a release 4, things work. When connected to release 5:
# sho int vfc4
vfc4 is down (Initializing)
interface port-channel4
  switchport mode trunk
  switchport trunk allowed vlan 10
  speed 10000
  vpc 4
interface vfc4
  bind interface Ethernet1/4
  no shutdown
  spanning-tree port type edge
  channel-group 4
