06-23-2013 01:03 PM
Hello guys,
I was wondering if it was possible to create a vsan trunk between the cisco UCS 6200 FI and a Nexus 5500 UP.
I see how to configure vsan trunking on UCS and on Nexus 5500 but it is said in the Nexus config guide that :
Trunking configurations are only applicable to E ports
I cannot remember the port type negotiated between UCS and Nexus.
Does anyone ever try this before ?
Kind Regards,
Thomas
06-24-2013 08:55 AM
Hi Thomas,
If UCS is running in Switched mode then you will have E port
If UCS is running End-Host (NPV) mode then you will use Trunking Fport feature to MDS/N5K NPIV core switch.
Please see this sample for additional information on Trunking and UCS-MDS trunking configuration:
https://supportforums.cisco.com/docs/DOC-14838
I hope this helps.
Carlos
06-24-2013 10:40 AM
Carlos,
is f-port-trunking supported on N5K ?
@dynamoxxx
06-24-2013 11:25 AM
Hi Carlos,
Thanks for your quick response.
I will try tommorrow in my lab.
As said by Dynamoxxx, Do you think it is possible on N5K ?
The only configuration I've found in N5K Configuration guide was for TE and not TF ...
Thomas
06-24-2013 12:25 PM
Yes. This is supported on N5K.
You will use a SAN PORT CHANNEL on N5K.
I found this for you:
06-24-2013 12:34 PM
thank you Carlos
@dynamoxxx
06-25-2013 02:07 AM
Thanks for your quick response guys.
Sadly I cannot try in my lab so I will wait to go back to my client.
I'll let you know what happened.
Thomas
