01-27-2016 03:30 AM
Hello!
We got 10 Cisco SG300-20 for using with pro-audio equipment ("Lab.grouppen PLM serries" amplifiers, by using DANTE network) and 2 of them are working incorrectly:
- after pluging system with SG300-20 to power, switch is loading whyle power indicator is flashing and then it ready to work when solid, but after that switch is not respond to any action. I mean that "act" indicators on used ports are flashing and show some activity whyle trying to access configuration web-interface for example, or trying to ping switch by his IP adress.
- then when we wait 40-60 minutes switch starts working and respond to our audio-controllling software and averything is grate till next power off and whaiting more the 1-2 hours, same problem apears.
- By the way 8 others switches are working good, and all 10 of them has same firmware (ver. 1.3.5.58) and configuration. but this problem apears with older firmware
- also hard reset device and reconfiguring it again is not helped.
can we fix it?
Thank You!
02-02-2016 02:52 PM
02-04-2016 03:18 AM
Thank you!
we tryed do 2-3 p. of your advice and no changes. We'll try connect to console and figure what happens.
sooner i provide you RAM-logs from good and not good switches (they are different) may be someone can tell what wrong.
