Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3657 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5342 Views
  • 1 replies
  • 16 Helpful votes
We have our DHCP server on the network, that dhcp server is working on linux and configuring all other switches and  PC desktop as usual, we have 2960 plus switches mostly, but recently we purchased 3650 switch and we trying to configure it. Usually ...
Hi,I have multiple SG200-50 switces which i have successfully upgraded the boot code and firmware without issues.However one switch simply refuses to be upgraded via HTTP or TFTP, it is running FW 1.2.9.44 and Boot 1.1.0.6.I have downloaded all FW ve...
Hi, Cisco support told me that SF200 & SG200 support MAB (MAC Authentication Bypass) in order to authenticate a device by a RADIUS through its MAC address. I cannot find it in administration guide, like : http://www.cisco.com/c/dam/en/us/td/docs/swit...
Hello together, i have a small problem with my SG300-20 Switch. I have connected a WAP561 WLAN Access Point with a Power Injector to the Switch. The WAP561 get no IP Address, the Smartport Type is "Wireless Access Point".   Does somebody has any ide...
I seem to have a problem using a /30 mask with my SG300-28 switch in L3 mode.  I want to isolate my router in a separate VLAN.  I had a VLAN created with a /24 mask and it seems to work well.  I tried to change the mask on both the switch and the rou...
Lee Cox by Level 2
  • 576 Views
  • 3 replies
Hello! We got 10 Cisco SG300-20 for using with pro-audio equipment ("Lab.grouppen PLM serries" amplifiers, by using DANTE network) and 2 of them are working incorrectly: - after pluging system with SG300-20 to power, switch is loading whyle power ind...
Just picked up a SG500-52 for the new office addition and we just purchased IP phones. I've configured 1 port with voice vlan 41 and data 100 trunked and the computer and phone both work. Even when I plug the computer directly in the switch it still ...
jbpollard by Level 1
  • 1371 Views
  • 5 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
