2*SG550XG-8F8T ( Nativ Stack ) & total outage at Dell Lifecycle Manager download Firmware update of a R7415
henrihoffmann
have here a few ESXi hosts with redundancy across 2 stack units (iSCSI plus Etherchannel for non iSCSI).
The stack rebooted a lot of times as I started a firmware download from ftp.dell.com via the lifecycle manager.
Even the master unit was not pingable. Therefor the SAN gave up and the VMs too (had to restore 6 VMs from backup).
Have issues with the boxes since 2 years. Firmware is up-to-date (as always in the past).
Another problem occurred later on, the Etherchannel hashing was out-of-sync between the switch and the ESXi hosts, so
some connections were possible, some not. Got it fixed by plugging/reinsert both cables.
I would like to get this fixed. How to achieve this? The there any way to get an technical (who is able to analyse this kind to problems and fix it ) involved?
Henri
2147442700 2019-Mar-26 23:04:04 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147442825 2019-Mar-26 22:57:30 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147442930 2019-Mar-26 22:50:53 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147443044 2019-Mar-26 22:38:33 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147443212 2019-Mar-26 22:31:23 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147443675 2019-Mar-26 22:24:18 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147443798 2019-Mar-26 22:17:07 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147443898 2019-Mar-26 22:10:05 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147444333 2019-Mar-26 21:41:45 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147444459 2019-Mar-26 21:34:44 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147444601 2019-Mar-26 21:21:14 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147444713 2019-Mar-26 21:07:00 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147444896 2019-Mar-26 20:52:45 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147445031 2019-Mar-26 20:45:45 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147445129 2019-Mar-26 20:38:45 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147476883 2019-Mar-12 09:10:57 Alert %STCK SYSL-A-UNITMSG: UNIT ID 2,Msg:%HAL_db-F-BOXCovIfUnitFailed: HALC_db_convert_ifIndex_to_unit_id: ifIndex 0 BOXG_convert_ifIndex_to_unit_id Failed *****  FATAL ERROR *****  Reporting Task: SFSM. Software Version: 2.4.5.71 (date Nov  4 2018 time 19:41:09) ros[0x2e6070] ros(HOSTG_fatal_error+0x8)[0x2e84d8] ros (OSSYSG_fatal_error+0x270)[0x887714] ros[0x69f9e0] ros(HALC_db_convert_ifIndex_to_unit_id+0x30)[0xba81a4] ros(HALC_db_rel_ifIndex_get_port_list+0x94)[0xba8df c] ros[0xbdf53c] ros(NETP_l2_get_autoneg_capabilities+0x54)[0xa4ea04] ros(NETP_l2_get_ifIndex_parameters+0x3bc)[0xa4f0d4] ros[0x9be750] ros[0x9bf9a4] /lib
2147477022 2019-Feb-01 09:04:41 Alert %STCK SYSL-A-UNITMSG: UNIT ID 1,Msg:%HAL_db-F-BOXCovIfUnitFailed: HALC_db_convert_ifIndex_to_unit_id: ifIndex 0 BOXG_convert_ifIndex_to_unit_id Failed *****  FATAL ERROR *****  Reporting Task: SFSM. Software Version: 2.4.5.71 (date Nov  4 2018 time 19:41:09) ros[0x2e6070] ros(HOSTG_fatal_error+0x8)[0x2e84d8] ros (OSSYSG_fatal_error+0x270)[0x887714] ros[0x69f9e0] ros(HALC_db_convert_ifIndex_to_unit_id+0x30)[0xba81a4] ros(HALC_db_rel_ifIndex_get_port_list+0x94)[0xba8df c] ros[0xbdf53c] ros(NETP_l2_get_autoneg_capabilities+0x54)[0xa4ea04] ros(NETP_l2_get_ifIndex_parameters+0x3bc)[0xa4f0d4] ros[0x9be750] ros[0x9bf9a4] /lib
2147477157 2019-Jan-14 09:16:09 Alert %STCK SYSL-A-UNITMSG: UNIT ID 1,Msg:%HAL_db-F-BOXCovIfUnitFailed: HALC_db_convert_ifIndex_to_unit_id: ifIndex 0 BOXG_convert_ifIndex_to_unit_id Failed *****  FATAL ERROR *****
2147477295 2018-Dec-14 16:31:40 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147477401 2018-Dec-14 15:15:35 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147477487 2018-Dec-14 14:34:58 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147477620 2018-Dec-14 12:08:41 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147477717 2018-Dec-14 12:06:08 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147477814 2018-Dec-14 12:03:12 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147477911 2018-Dec-14 11:59:57 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147477989 2018-Dec-14 11:55:39 Error %Stack-E-VERSION-UPDATE-FAILED: Unit 2 - failed to update image
2147478032 2018-Dec-14 11:53:59 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147478124 2018-Dec-14 11:51:11 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147478218 2018-Dec-14 11:48:15 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147478338 2018-Dec-14 11:42:49 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147478444 2018-Dec-14 11:36:58 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147478535 2018-Dec-14 11:33:54 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147478642 2018-Dec-14 11:30:50 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147478737 2018-Dec-14 11:27:30 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147478828 2018-Dec-14 11:24:45 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147478925 2018-Dec-14 11:21:38 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479032 2018-Dec-14 11:18:35 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479123 2018-Dec-14 11:15:27 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479214 2018-Dec-14 11:12:15 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479317 2018-Dec-14 11:08:53 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479412 2018-Dec-14 11:06:00 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479508 2018-Dec-14 11:03:03 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479602 2018-Dec-14 11:00:13 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479696 2018-Dec-14 10:57:06 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479792 2018-Dec-14 10:54:08 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479899 2018-Dec-14 10:48:30 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147479990 2018-Dec-14 10:45:43 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147480127 2018-Dec-14 10:42:45 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147480220 2018-Dec-14 10:39:42 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
2147480312 2018-Dec-14 10:36:30 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 2 reason : connection timeout. Unit will be rebooted .
0 Replies 0
